Zum Hauptinhalt wechseln
Dell Inspiron 14 3468 Hard-Drive Replacement
Was du brauchst
  1. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: Schritt 1, Bild 1 von 1
    • Remove the screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Hard-Drive Cable: Schritt 2, Bild 1 von 1
    • Open the latch and disconnect the hard-drive cable from the system board.
  3. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly off the computer base.
  4. Dell Inspiron 14 3468 Hard-Drive Replacement, Removing the Screws: Schritt 4, Bild 1 von 1
    • Remove the screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 14 3468 Hard-Drive Replacement, Lifting the Hard-Drive  Bracket: Schritt 5, Bild 1 von 1
    • Lift the hard-drive bracket off the hard drive.
  6. Dell Inspiron 14 3468 Hard-Drive Replacement, Disconnecting the Interposer: Schritt 6, Bild 1 von 1
    • Disconnect the interposer from the hard drive.
  7. Dell Inspiron 14 3468 Hard-Drive Replacement, Connecting the Interposer: Schritt 7, Bild 1 von 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screws: Schritt 8, Bild 1 von 1
    • Align the screw holes on the hard-drive bracket with the screw holes on the hard drive.
  9. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: Schritt 9, Bild 1 von 1
    • Replace the screws that secure the hard-drive bracket to the hard drive.
  10. Dell Inspiron 14 3468 Hard-Drive Replacement, Align the Screw Holes: Schritt 10, Bild 1 von 1
    • Align the screw holes on the hard-drive assembly with the screw holes on the computer base.
  11. Dell Inspiron 14 3468 Hard-Drive Replacement, Securing the Screws: Schritt 11, Bild 1 von 1
    • Replace the screws that secure the hard-drive assembly to the computer base.
  12. Dell Inspiron 14 3468 Hard-Drive Replacement, Sliding the Hard-Drive Cable: Schritt 12, Bild 1 von 1
    • Slide the hard-drive cable into the system board and close the latch to secure the cable.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
darrius
5.213 Reputation
30 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 144
