Zum Hauptinhalt wechseln
HP Pavilion N3350 Optical Drive Replacement
Was du brauchst
  1. HP Pavilion N3350 Optical Drive Replacement, Keyboard: Schritt 1, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Open your laptop. Beneath the screen, here is a large plastic piece that contains slots for a speaker, the power button, and numerous indicator lights.
    • To remove this, pry it open with a spudger tool gently. It should pop out of place.
  2. HP Pavilion N3350 Optical Drive Replacement: Schritt 2, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement: Schritt 2, Bild 2 von 2
    • Remove the three 6mm screws using a Phillips #1 screwdriver.
    • Once the screws are removed, the keyboard is free from the base of the laptop.
  3. HP Pavilion N3350 Optical Drive Replacement: Schritt 3, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement: Schritt 3, Bild 2 von 2
    • Disconnect the green ribbon cable using a plastic opening tool.
  4. HP Pavilion N3350 Optical Drive Replacement, Optical Drives: Schritt 4, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement, Optical Drives: Schritt 4, Bild 2 von 2
    • Remove the 6 millimeter screws indicated with a Phillips #1 screwdriver.
    • Remove the top plastic covering from the base of the device.
  5. HP Pavilion N3350 Optical Drive Replacement: Schritt 5, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement: Schritt 5, Bild 2 von 2
    • Use a plastic opening tool to disconnect both cable connectors gently.
  6. HP Pavilion N3350 Optical Drive Replacement: Schritt 6, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement: Schritt 6, Bild 2 von 2
    • Once these cables are disconnected, the optical drives can be found inside.
    • This particular laptop has a CD/DVD combo drive on the left, and a floppy disc drive on the right.
  7. HP Pavilion N3350 Optical Drive Replacement: Schritt 7, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement: Schritt 7, Bild 2 von 2
    • The 1 centimeter screws indicated need to be removed using a Phillips #1 screwdriver to free the CD/DVD combo drive.
    • Once freed, the CD/DVD combo drive should slide out and remove easily.
  8. HP Pavilion N3350 Optical Drive Replacement: Schritt 8, Bild 1 von 2 HP Pavilion N3350 Optical Drive Replacement: Schritt 8, Bild 2 von 2
    • The 1 centimeter screws indicated must be removed with a Phillips #1 screwdriver to free the floppy disc drive.
    • Remove the floppy disc drive from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Lyndon Davis
124 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team S3-G8, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G8, Peak Spring 2018
UMASSD-PEAK-S18S3G8
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 248
