Zum Hauptinhalt wechseln
Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink
Was du brauchst
  1. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: Schritt 1, Bild 1 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: Schritt 1, Bild 2 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Battery: Schritt 1, Bild 3 von 3
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 2, Bild 1 von 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 2, Bild 2 von 2
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 3, Bild 1 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 3, Bild 2 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 3, Bild 3 von 3
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: Schritt 4, Bild 1 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: Schritt 4, Bild 2 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Back Panel: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: Schritt 5, Bild 1 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: Schritt 5, Bild 2 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink, Cooling Fan with Heat Sink: Schritt 5, Bild 3 von 3
    • The ribbon and wire must be moved out of the way of the fan.
    • Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
    • Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
  6. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 6, Bild 1 von 2 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 6, Bild 2 von 2
    • Unscrew the two 3mm Phillips head screws on each fan using the Phillips #00 screwdriver.
  7. Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 7, Bild 1 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 7, Bild 2 von 3 Toshiba Satellite L55t-B5271 Cooling Fan Replacement with Heat Sink: Schritt 7, Bild 3 von 3
    • Unscrew the four, 3mm Phillips head screws holding the last piece to the laptop using a Phillips #00 screwdriver.
    • Gently pull the cooling fan with heat sink off the laptop and set aside.
Abschluss
Noelle Dulude
480 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S3-G3, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S3-G3, Peak Spring 2018
UMASSD-PEAK-S18S3G3
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 554
