Zum Hauptinhalt wechseln
HP Pavilion ze5000 Screen Replacement
Was du brauchst
  1. HP Pavilion ze5000 Screen Replacement, Screen: Schritt 1, Bild 1 von 3 HP Pavilion ze5000 Screen Replacement, Screen: Schritt 1, Bild 2 von 3 HP Pavilion ze5000 Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Remove two 5.0 mm Philips #0 screws on the hinge of the device
  2. HP Pavilion ze5000 Screen Replacement: Schritt 2, Bild 1 von 2 HP Pavilion ze5000 Screen Replacement: Schritt 2, Bild 2 von 2
    • Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
  3. HP Pavilion ze5000 Screen Replacement: Schritt 3, Bild 1 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 3, Bild 2 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 3, Bild 3 von 3
    • Remove the connection between the plastic case and interior of the device
  4. HP Pavilion ze5000 Screen Replacement: Schritt 4, Bild 1 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 4, Bild 2 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the connection from the exposed hinge and interior of the device
  5. HP Pavilion ze5000 Screen Replacement: Schritt 5, Bild 1 von 2 HP Pavilion ze5000 Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
  6. HP Pavilion ze5000 Screen Replacement: Schritt 6, Bild 1 von 2 HP Pavilion ze5000 Screen Replacement: Schritt 6, Bild 2 von 2
    • Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
  7. HP Pavilion ze5000 Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
    • It may be easier to use tweezers for this part
  8. HP Pavilion ze5000 Screen Replacement: Schritt 8, Bild 1 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 8, Bild 2 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 8, Bild 3 von 3
    • Unscrew the six 5.0 mm Philips #0 screws underneath the caps
  9. HP Pavilion ze5000 Screen Replacement: Schritt 9, Bild 1 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 9, Bild 2 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 9, Bild 3 von 3
    • Using a spudger, pry the plastic casing off of the screen.
  10. HP Pavilion ze5000 Screen Replacement: Schritt 10, Bild 1 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 10, Bild 2 von 3 HP Pavilion ze5000 Screen Replacement: Schritt 10, Bild 3 von 3
    • Remove four 5.0 mm Philips #0 screws located in the corners of the screen
    • These screws locations will be close to the screws locations in step 2.
    • During reassembly, make sure you do not confuse the proper screw placements from this step and step 4.
  11. HP Pavilion ze5000 Screen Replacement: Schritt 11, Bild 1 von 2 HP Pavilion ze5000 Screen Replacement: Schritt 11, Bild 2 von 2
    • Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
    • There will be two 3.5 mm Philips screws on each side
Abschluss
Eric Beaudry
823 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team S2-G7, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G7, Bernier Spring 2018
UMASSD-BERNIER-S18S2G7
2 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 124
