Zum Hauptinhalt wechseln
Acer Aspire E5-511p-C6US RAM Replacement
Was du brauchst
  1. Acer Aspire E5-511p-C6US RAM Replacement, Battery: Schritt 1, Bild 1 von 3 Acer Aspire E5-511p-C6US RAM Replacement, Battery: Schritt 1, Bild 2 von 3 Acer Aspire E5-511p-C6US RAM Replacement, Battery: Schritt 1, Bild 3 von 3
    • On the back of the laptop, there is a sliding lock. Push the slider and the battery will unlock
  2. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 2, Bild 1 von 1
    • Pull battery to remove.
  3. Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: Schritt 3, Bild 1 von 2 Acer Aspire E5-511p-C6US RAM Replacement, Optical Drive: Schritt 3, Bild 2 von 2
    • Remove the 1 screw just above the battery with a Phillips #1 screwdriver.
  4. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 4, Bild 1 von 2 Acer Aspire E5-511p-C6US RAM Replacement: Schritt 4, Bild 2 von 2
    • Pull the Optical Drive out
  5. Acer Aspire E5-511p-C6US RAM Replacement, Keyboard: Schritt 5, Bild 1 von 1
    • Remove the 17 Phillips #1 screws remaining on the back side of the laptop
  6. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 6, Bild 1 von 3 Acer Aspire E5-511p-C6US RAM Replacement: Schritt 6, Bild 2 von 3 Acer Aspire E5-511p-C6US RAM Replacement: Schritt 6, Bild 3 von 3
    • Flip over the laptop, Using the spudger separate the body of the keyboard from the base of the laptop.
  7. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 7, Bild 1 von 2 Acer Aspire E5-511p-C6US RAM Replacement: Schritt 7, Bild 2 von 2
    • Carefully lift the keyboard and disconnect the 3 ribbon style connectors from the computers boards.
  8. Acer Aspire E5-511p-C6US RAM Replacement, Fan: Schritt 8, Bild 1 von 2 Acer Aspire E5-511p-C6US RAM Replacement, Fan: Schritt 8, Bild 2 von 2
    • Disconnect the cord from the fan
  9. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 9, Bild 1 von 1
    • Remove the 2 #1 Phillips screws
  10. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 10, Bild 1 von 1
    • now the fan can be pulled from the laptop
  11. Acer Aspire E5-511p-C6US RAM Replacement, RAM: Schritt 11, Bild 1 von 1
    • Disconnect the 2 plugs remaining on the computer
  12. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 12, Bild 1 von 1
    • Remove the last 2 #1 Philips screws from the body
  13. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 13, Bild 1 von 1
    • Remove the 2 #1 Phillips screws, then slide the metal cover back and away
  14. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 14, Bild 1 von 1
    • Remove the board from the laptop body, flip over for access to the ram
  15. Acer Aspire E5-511p-C6US RAM Replacement: Schritt 15, Bild 1 von 2 Acer Aspire E5-511p-C6US RAM Replacement: Schritt 15, Bild 2 von 2
    • Press down on the spring clips on either side of the ram, It will unlock and can be removed
Abschluss
Aaron
562 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S2-G1, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S2-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S2G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 15
Insgesamt: 662
