Zum Hauptinhalt wechseln
HP Pavilion G60-247CL Speaker Replacement
Was du brauchst
  1. HP Pavilion G60-247CL Speaker Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement, Battery: Schritt 1, Bild 3 von 3
    • Press down and to the right on the battery lock slide.
    • Once slid over to the right the battery will pop up and out.
  2. HP Pavilion G60-247CL Speaker Replacement, Screen: Schritt 2, Bild 1 von 1
    • Remove the seven Phillips #1 screws from the back side of the laptop.
  3. HP Pavilion G60-247CL Speaker Replacement: Schritt 3, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 3, Bild 2 von 2
    • Remove the seven Phillips #0 screws from the battery compartment.
  4. HP Pavilion G60-247CL Speaker Replacement: Schritt 4, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 4, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 4, Bild 3 von 3
    • Turn the computer around to the front side.
    • Using an opening tool (Spudger), prop open the keyboard casing.
  5. HP Pavilion G60-247CL Speaker Replacement: Schritt 5, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 5, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 5, Bild 3 von 3
    • Carefully lift up the keyboard.
    • Gently pull up the connecting wire clip (located in the middle) to completely detach the keyboard.
  6. HP Pavilion G60-247CL Speaker Replacement: Schritt 6, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 6, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 6, Bild 3 von 3
    • At the top right of the laptop there will be another wire clip holding the keyboard casing.
    • Carefully pull out the wire clip to fully detach the covering.
  7. HP Pavilion G60-247CL Speaker Replacement: Schritt 7, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 7, Bild 2 von 2
    • At the top right of the laptop remove the black wire from under the metal tabs using the tweezers.
  8. HP Pavilion G60-247CL Speaker Replacement: Schritt 8, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 8, Bild 2 von 2
    • Remove the black wire from the top right corner by gently pulling outward.
  9. HP Pavilion G60-247CL Speaker Replacement: Schritt 9, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 9, Bild 2 von 2
    • At the top left of the computer remove the black clip using the opening tool.
    • Push the opening tool to the right to pop out the clip.
  10. HP Pavilion G60-247CL Speaker Replacement: Schritt 10, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 10, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 10, Bild 3 von 3
    • Locate at the bottom left of the computer a white clip.
    • Using an opening tool, prop out the white clip.
  11. HP Pavilion G60-247CL Speaker Replacement: Schritt 11, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 11, Bild 2 von 2
    • On the left side of the computer locate the black wire with the clear clip.
    • Gently pull the wire to the right to detach it.
  12. HP Pavilion G60-247CL Speaker Replacement: Schritt 12, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 12, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 12, Bild 3 von 3
    • At the top corners of the computer, unscrew the three Phillips #0 screws.
    • Lift up the top half of the computer carefully.
  13. HP Pavilion G60-247CL Speaker Replacement: Schritt 13, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 13, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 13, Bild 3 von 3
    • Locate the two screws at the bottom corners of the screen.
    • Using the tweezers remove the rubber black covering over the screw.
    • Remove the two Phillips #0 screws.
  14. HP Pavilion G60-247CL Speaker Replacement: Schritt 14, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 14, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 14, Bild 3 von 3
    • Using the opening tool, prop off the screen covering.
    • Remove the covering to expose the screen completely.
  15. HP Pavilion G60-247CL Speaker Replacement: Schritt 15, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 15, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 15, Bild 3 von 3
    • Remove the bottom two screen bearings.
    • Using a Phillips 1 screwdriver, remove the two screws on each side.
  16. HP Pavilion G60-247CL Speaker Replacement: Schritt 16, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 16, Bild 2 von 2
    • Using the tweezers remove the red and white wire from the bottom of the screen.
  17. HP Pavilion G60-247CL Speaker Replacement: Schritt 17, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 17, Bild 2 von 2
    • Prop the screen up slightly .
    • Using the tweezers unclip the white wire.
  18. HP Pavilion G60-247CL Speaker Replacement: Schritt 18, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 18, Bild 2 von 2
    • While the screen is still propped open remove the black wire from the bottom middle of the screen by pulling gently.
  19. HP Pavilion G60-247CL Speaker Replacement: Schritt 19, Bild 1 von 1
    • Remove the screen from the outer casing carefully.
  20. HP Pavilion G60-247CL Speaker Replacement, RAM: Schritt 20, Bild 1 von 1
    • Locate RAM access door on the bottom side of the laptop.
  21. HP Pavilion G60-247CL Speaker Replacement: Schritt 21, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 21, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 21, Bild 3 von 3
    • Remove the two screws holding down the RAM access door with a Phillips #1 screwdriver.
  22. HP Pavilion G60-247CL Speaker Replacement: Schritt 22, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 22, Bild 2 von 2
    • Lift up on the RAM cover and remove it to reveal RAM sticks.
  23. HP Pavilion G60-247CL Speaker Replacement: Schritt 23, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 23, Bild 2 von 2
    • Gently pull apart the two metal tabs located on both sides of the stick of RAM.
  24. HP Pavilion G60-247CL Speaker Replacement: Schritt 24, Bild 1 von 1
    • Gently lift the RAM stick up and out of its seat.
  25. HP Pavilion G60-247CL Speaker Replacement: Schritt 25, Bild 1 von 1
    • Repeat the previous two steps for the remaining stick of RAM.
  26. HP Pavilion G60-247CL Speaker Replacement, Speakers: Schritt 26, Bild 1 von 1
    • With the battery and RAM removed, locate the hard drive access panel.
  27. HP Pavilion G60-247CL Speaker Replacement: Schritt 27, Bild 1 von 1
    • Remove two 1.2 mm Philips#01 screws.
  28. HP Pavilion G60-247CL Speaker Replacement: Schritt 28, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 28, Bild 2 von 2
    • After the screws are removed, slide the hard drive panel to right to remove it.
  29. HP Pavilion G60-247CL Speaker Replacement: Schritt 29, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 29, Bild 2 von 2
    • Identify the three screws holding the hard drives cover in place.
    • Remove each screw using a #0 Philips screwdriver to reveal the hard drive.
    • This particular laptop does not contain a hard drive-- yours will.
  30. HP Pavilion G60-247CL Speaker Replacement: Schritt 30, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 30, Bild 2 von 2
    • Locate the storage battery, next to the hard drive.
    • Genlty pop out storage battery with fingers.
  31. HP Pavilion G60-247CL Speaker Replacement: Schritt 31, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 31, Bild 2 von 2
    • Locate the Wifi card cover panel, left of the RAM.
    • Using a Philips #1 screwdriver remove the screw holding the panel down.
  32. HP Pavilion G60-247CL Speaker Replacement: Schritt 32, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 32, Bild 2 von 2
    • Lift up on the screw side to remove the panel.
  33. HP Pavilion G60-247CL Speaker Replacement: Schritt 33, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 33, Bild 2 von 2
    • As the screws are removed the Wifi card will pop up.
  34. HP Pavilion G60-247CL Speaker Replacement: Schritt 34, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 34, Bild 2 von 2
    • Remove Wifi card by pulling to the left of the laptop.
  35. HP Pavilion G60-247CL Speaker Replacement: Schritt 35, Bild 1 von 1
    • Flip over to the top view
    • Remove five 1.2 mm Philips#00 swrews
  36. HP Pavilion G60-247CL Speaker Replacement: Schritt 36, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 36, Bild 2 von 2
    • Using a spudger unclip the casing around all corners and edges.
  37. HP Pavilion G60-247CL Speaker Replacement: Schritt 37, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 37, Bild 2 von 2
    • lift up the casing and remove to reveal the speakers.
  38. HP Pavilion G60-247CL Speaker Replacement: Schritt 38, Bild 1 von 1
    • Remove highlighted 1.2 mm Philips #00 screw from right speaker.
  39. HP Pavilion G60-247CL Speaker Replacement: Schritt 39, Bild 1 von 2 HP Pavilion G60-247CL Speaker Replacement: Schritt 39, Bild 2 von 2
    • Using a spudger, remove the highlighted white wire.
  40. HP Pavilion G60-247CL Speaker Replacement: Schritt 40, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 40, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 40, Bild 3 von 3
    • Using a spudger, remove both additional highlighted wires from the motherboad.
  41. HP Pavilion G60-247CL Speaker Replacement: Schritt 41, Bild 1 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 41, Bild 2 von 3 HP Pavilion G60-247CL Speaker Replacement: Schritt 41, Bild 3 von 3
    • Lift up and out each speaker from the base.
Abschluss
UMass Dartmouth, Team S4-G5, Covino Spring 2018 Mitglied von UMass Dartmouth, Team S4-G5, Covino Spring 2018
UMASSD-COVINO-S18S4G5
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 272
