Einleitung
If the CD drive is not playing your movies or musical discs, a replacement might need to be done. This guide will take you through the process of removing and replacing the CD drive.
Was du brauchst
Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
Push the switch to the right, toward the inside of the computer to dislodge the battery.
Finally, pull the battery outwards and away from the laptop as depicted in this image.
Using the Phillips #1 screwdriver, remove the indicated 6mm screw holding the CD drive.
