Zum Hauptinhalt wechseln
HP Elitebook 2740p Screen Replacement
Was du brauchst
  1. HP Elitebook 2740p Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the lock tab to the right.
  2. HP Elitebook 2740p Screen Replacement: Schritt 2, Bild 1 von 1
    • Lift and remove the battery from the battery compartment.
  3. HP Elitebook 2740p Screen Replacement, Screen: Schritt 3, Bild 1 von 3 HP Elitebook 2740p Screen Replacement, Screen: Schritt 3, Bild 2 von 3 HP Elitebook 2740p Screen Replacement, Screen: Schritt 3, Bild 3 von 3
    • Locate the radio antenna on the right side of the top edge of the screen. Slide the latch to release the antenna.
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws recessed in the antenna housing.
  4. HP Elitebook 2740p Screen Replacement: Schritt 4, Bild 1 von 3 HP Elitebook 2740p Screen Replacement: Schritt 4, Bild 2 von 3 HP Elitebook 2740p Screen Replacement: Schritt 4, Bild 3 von 3
    • Use a metal spudger to separate bezel from laptop body. there are tabs holding the bezel on along the entire bezel.
    • Pay special attention to the hinge cover at the bottom. It has tabs at both the top and bottom.
    • Remove the bezel from the laptop.
  5. HP Elitebook 2740p Screen Replacement: Schritt 5, Bild 1 von 3 HP Elitebook 2740p Screen Replacement: Schritt 5, Bild 2 von 3 HP Elitebook 2740p Screen Replacement: Schritt 5, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the eight 4 mm screws that hold the frame of the screen in place.
    • Use a Phillips #00 screwdriver to remove the single 3 mm screw at the corner of the frame.
  6. HP Elitebook 2740p Screen Replacement: Schritt 6, Bild 1 von 3 HP Elitebook 2740p Screen Replacement: Schritt 6, Bild 2 von 3 HP Elitebook 2740p Screen Replacement: Schritt 6, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the two 4 mm screws that hold the tilt button in place.
    • Remove the tilt button.
  7. HP Elitebook 2740p Screen Replacement: Schritt 7, Bild 1 von 3 HP Elitebook 2740p Screen Replacement: Schritt 7, Bild 2 von 3 HP Elitebook 2740p Screen Replacement: Schritt 7, Bild 3 von 3
    • Use a Phillips #0 screwdriver to remove the three screws that secure the tablet-mode button board.
    • Disconnect the two blue ribbon cables and gently pull them free.
    • Remove the PCB board from the screen housing.
  8. HP Elitebook 2740p Screen Replacement: Schritt 8, Bild 1 von 3 HP Elitebook 2740p Screen Replacement: Schritt 8, Bild 2 von 3 HP Elitebook 2740p Screen Replacement: Schritt 8, Bild 3 von 3
    • Remove the gray rubber pad at the top of the screen next to the camera.
    • Remove the 3mm screw with a Phillips #0 screwdriver
    • Carefully tilt the screen down onto the keayboard
  9. HP Elitebook 2740p Screen Replacement: Schritt 9, Bild 1 von 2 HP Elitebook 2740p Screen Replacement: Schritt 9, Bild 2 von 2
    • Fold the protective foil back from the ribbon cables.
  10. HP Elitebook 2740p Screen Replacement: Schritt 10, Bild 1 von 3 HP Elitebook 2740p Screen Replacement: Schritt 10, Bild 2 von 3 HP Elitebook 2740p Screen Replacement: Schritt 10, Bild 3 von 3
    • Unseat display ribbon cables.
    • Ribbon cables are secured with tape. Do not force the cables out of their sockets.
    • Remove the screen.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Joseph Hazel
329 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S8-G4, Valliere Spring 2018 Mitglied von UMass Dartmouth, Team S8-G4, Valliere Spring 2018
UMASSD-VALLIERE-S18S8G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 15
Insgesamt: 1,356
