Zum Hauptinhalt wechseln
Epiphone ES-335 PRO Pickguard Replacement
Was du brauchst
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: Schritt 1, Bild 1 von 1
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: Schritt 2, Bild 1 von 2 Epiphone ES-335 PRO Pickguard Replacement: Schritt 2, Bild 2 von 2
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
Abschluss
Ein Kommentar
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 19
Letzte 30 Tage: 70
Insgesamt: 4,518
