Zum Hauptinhalt wechseln
Display Assembly
Was du brauchst
    • Pull straight up on the pull-tab that is attached to the display-feed flex cable to disconnect the cable from the system board.
    • Disconnect the antenna cable.
    • Close the display.
    • Turn the computer upside down with the back of the computer facing you.
  1. Display Assembly, Remove the Screws: Schritt 2, Bild 1 von 1
    • From the bottom of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  2. Display Assembly, Remove the Screws: Schritt 3, Bild 1 von 2 Display Assembly, Remove the Screws: Schritt 3, Bild 2 von 2
    • From the back of the computer, remove the two M2.5 x 8-mm screws labeled "D."
  3. Display Assembly, Removing the Cables: Schritt 4, Bild 1 von 1
    • Turn the computer right-side up and open the display.
    • Carefully remove the antenna cable and the display cables from their routing guides.
  4. Display Assembly, Lifting the Display Assembly: Schritt 5, Bild 1 von 1
    • NOTICE: Be careful not to damage the display switch when removing the display.
    • Lift the display assembly out of the computer base.
Abschluss
Terrence15
79.091 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 523
