Zum Hauptinhalt wechseln
Dell Inspiron N4110 Screen Replacement
Was du brauchst
  1. Dell Inspiron N4110 Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure the laptop is off and unplugged before starting this step.
    • Locate the battery on the underside of the laptop.
    • Push the two battery clips following the direction of the arrows.
  2. Dell Inspiron N4110 Screen Replacement: Schritt 2, Bild 1 von 1
    • Push upward from the base of the battery.
  3. Dell Inspiron N4110 Screen Replacement: Schritt 3, Bild 1 von 1
    • Pull battery away from computer until it is fully removed.
  4. Dell Inspiron N4110 Screen Replacement, Screen: Schritt 4, Bild 1 von 3 Dell Inspiron N4110 Screen Replacement, Screen: Schritt 4, Bild 2 von 3 Dell Inspiron N4110 Screen Replacement, Screen: Schritt 4, Bild 3 von 3
    • Use your hands to remove the plastic cover from around the screen.
    • This can seem difficult, but it can be done.
  5. Dell Inspiron N4110 Screen Replacement: Schritt 5, Bild 1 von 2 Dell Inspiron N4110 Screen Replacement: Schritt 5, Bild 2 von 2
    • Unscrew the two 2.5x4 mm screws from the top of the screen.
  6. Dell Inspiron N4110 Screen Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron N4110 Screen Replacement: Schritt 6, Bild 2 von 2
    • Loosen the four 2.5x4 mm screws from the base of the screen.
    • This will allow the screen to lift from inside the top of the case.
  7. Dell Inspiron N4110 Screen Replacement: Schritt 7, Bild 1 von 3 Dell Inspiron N4110 Screen Replacement: Schritt 7, Bild 2 von 3 Dell Inspiron N4110 Screen Replacement: Schritt 7, Bild 3 von 3
    • Unscrew the four 2x3 mm screws from the two sides on both the top and bottom.
  8. Dell Inspiron N4110 Screen Replacement: Schritt 8, Bild 1 von 2 Dell Inspiron N4110 Screen Replacement: Schritt 8, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Use tweezers to peel the webcam away from the top of the laptop.
    • The webcam is only held in place by a webcam, this is easy to pull away from the screen.
  9. Dell Inspiron N4110 Screen Replacement: Schritt 9, Bild 1 von 3 Dell Inspiron N4110 Screen Replacement: Schritt 9, Bild 2 von 3 Dell Inspiron N4110 Screen Replacement: Schritt 9, Bild 3 von 3
    • Lift the adhesive flap from the cord that connects the computer to the screen.
    • You can then disconnect the cord from the screen.
  10. Dell Inspiron N4110 Screen Replacement: Schritt 10, Bild 1 von 1
    • The screen can now be fully removed from the computer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Abigail Keith
505 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S5-G1, Peak Spring 2018 Mitglied von UMass Dartmouth, Team S5-G1, Peak Spring 2018
UMASSD-PEAK-S18S5G1
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 22
Insgesamt: 1,220
