Zum Hauptinhalt wechseln
HP Pavilion DV9700 Optical Drive Replacement
Was du brauchst
  1. HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: Schritt 1, Bild 1 von 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: Schritt 1, Bild 2 von 3 HP Pavilion DV9700 Optical Drive  Replacement, Optical Drive: Schritt 1, Bild 3 von 3
    • Turn the device over so that the bottom is facing upward.
    • Find the screw with an imprint of a disk underneath it. It is located near the center of the device.
    • Remove this 6mm screw with a Philips #0 screwdriver.
    • This screw is very small, make sure to have an organized place to put it.
  2. HP Pavilion DV9700 Optical Drive  Replacement: Schritt 2, Bild 1 von 3 HP Pavilion DV9700 Optical Drive  Replacement: Schritt 2, Bild 2 von 3 HP Pavilion DV9700 Optical Drive  Replacement: Schritt 2, Bild 3 von 3
    • The optical drive is located toward the left side of the device.
    • Using a spudger, pry the optical drive away from the casing.
    • Pull the rest of the optical drive out with your hand.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Max Shangraw
507 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S6-G1, Bernier Spring 2018 Mitglied von UMass Dartmouth, Team S6-G1, Bernier Spring 2018
UMASSD-BERNIER-S18S6G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 326
