Zum Hauptinhalt wechseln
Dell Inspiron 13z N301z Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 13z N301z Display Assembly Replacement, Disconnecting the Antenna Cables: Schritt 1, Bild 1 von 1
    • Follow the instructions in Before You Begin.
    • Turn the computer over.
    • Disconnect the Mini-Card antenna cables from the computer base.
  2. Dell Inspiron 13z N301z Display Assembly Replacement, Opening the Display: Schritt 2, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 13z N301z Display Assembly Replacement, Disconnecting the Display Cable: Schritt 3, Bild 1 von 1
    • Disconnect the display cable and the camera cable from their connectors on the system board.
  4. Dell Inspiron 13z N301z Display Assembly Replacement, Removing the Cables: Schritt 4, Bild 1 von 1
    • Make a note of the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
  5. Dell Inspiron 13z N301z Display Assembly Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
    • Remove the six screws (three on each side) that secure the display assembly to the computer base.
  6. Dell Inspiron 13z N301z Display Assembly Replacement, Removing the Display Assembly: Schritt 6, Bild 1 von 1
    • Lift and remove the display assembly off the computer base.
  7. Dell Inspiron 13z N301z Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 1 von 2 Dell Inspiron 13z N301z Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 2 von 2
    • Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base.
  8. Dell Inspiron 13z N301z Display Assembly Replacement, Routing the Antenna Cables: Schritt 8, Bild 1 von 1
    • Route the Mini-Card antenna cables through the slot on the computer base.
  9. Dell Inspiron 13z N301z Display Assembly Replacement, Connecting the Cables: Schritt 9, Bild 1 von 1
    • Connect the display cable and the camera cable to their connectors on the system board.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 6
Letzte 30 Tage: 8
Insgesamt: 138
