Einleitung
In this guide, we will be showing you how to remove and replace the Display Assembly.
Was du brauchst
Turn the computer over.
Disconnect the Mini-Card antenna cables from the computer base.
Turn the computer over and open the display as far as possible.
Disconnect the display cable and the camera cable from their connectors on the system board.
Make a note of the routing of the Mini-Card antenna cables and remove the cables from the routing guides.
Remove the six screws (three on each side) that secure the display assembly to the computer base.
Lift and remove the display assembly off the computer base.
Place the NEW display assembly in position and replace the six screws (three on each side) that secure the display assembly to the computer base.
Route the Mini-Card antenna cables through the slot on the computer base.
Connect the display cable and the camera cable to their connectors on the system board.
