Zum Hauptinhalt wechseln
Dell Inspiron 13z N301z Hard-Drive Assembly Replacement
Was du brauchst
  1. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Removing the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the four screws that secure the hard-drive assembly to the computer base.
  2. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Connector Latch: Schritt 2, Bild 1 von 1
    • Lift the connector latch and pull the pull-tab to disconnect the hard-drive cable from the connector on the system board.
  3. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard-Drive Assembly: Schritt 3, Bild 1 von 1
    • Lift the hard-drive assembly out of the computer base.
  4. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Remove the Screws: Schritt 4, Bild 1 von 1
    • Remove the four screws that secure the hard-drive bracket to the hard drive.
  5. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: Schritt 5, Bild 1 von 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Lifting the Hard Drive: Schritt 5, Bild 2 von 2
    • Lift the hard drive out of the hard-drive bracket.
  6. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Disconnecting the Interposer: Schritt 6, Bild 1 von 1
    • Pull the interposer to disconnect it from the hard drive.
  7. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Connecting the Interposer: Schritt 7, Bild 1 von 1
    • Connect the interposer to the NEW hard drive.
  8. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: Schritt 8, Bild 1 von 2 Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive: Schritt 8, Bild 2 von 2
    • Place the hard drive in the hard-drive bracket.
  9. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: Schritt 9, Bild 1 von 1
    • Replace the four screws the hard-drive bracket to the hard drive.
  10. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Placing the Hard-Drive Assembly: Schritt 10, Bild 1 von 1
    • Place the hard-drive assembly in the computer base.
  11. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Sliding the Hard-Drive Cable: Schritt 11, Bild 1 von 1
    • Slide the hard-drive cable into the connector on the system board and press down on the latch to secure the hard-drive cable.
  12. Dell Inspiron 13z N301z Hard-Drive Assembly Replacement, Replace the Screws: Schritt 12, Bild 1 von 1
    • Replace the four screws that secure the hard-drive assembly to the computer base.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 206
