Zum Hauptinhalt wechseln
Dell Precision M4700 Hard Drive Replacement
Was du brauchst
  1. Dell Precision M4700 Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 2 Dell Precision M4700 Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Slide the release latch to unlock the battery.
    • Flip and remove the battery from the computer.
  2. Dell Precision M4700 Hard Drive Replacement, Base Cover: Schritt 2, Bild 1 von 2 Dell Precision M4700 Hard Drive Replacement, Base Cover: Schritt 2, Bild 2 von 2
    • Remove the screws that secure the base cover to the computer. Press the rubber tabs towards the rear of the computer to disengage the base cover.
    • Flip and remove the base cover from the computer.
  3. Dell Precision M4700 Hard Drive Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Remove the screws that secure the hard drive to the computer. Slide the hard -drive latch to the unlock position and pull out the hard drive from the computer.
  4. Dell Precision M4700 Hard Drive Replacement: Schritt 4, Bild 1 von 1
    • Flex the hard-drive bracket outward and pull out the hard drive from the bracket.
    • NOTE: A rubber filler is installed to the hard-drive bracket for 7 mm hard drives. It is designed to prevent vibrations and for correct installation of the 7 mm hard drives. 9 mm hard drives do not require the filler when installed into the hard-drive bracket.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Johnathan Hammond
44.830 Reputation
408 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 47
Insgesamt: 4,686
