Zum Hauptinhalt wechseln
Toshiba TDP-XP2 Fan Replacement
Was du brauchst
  1. Toshiba TDP-XP2 Fan Replacement, Fan: Schritt 1, Bild 1 von 3 Toshiba TDP-XP2 Fan Replacement, Fan: Schritt 1, Bild 2 von 3 Toshiba TDP-XP2 Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Start by removing the two screws on the bottom of the device as shown.
  2. Toshiba TDP-XP2 Fan Replacement: Schritt 2, Bild 1 von 2 Toshiba TDP-XP2 Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the top plastic cover from the device. The back is snapped on so it would help to have leverage from a prying tool.
    • Remove the ribbon cable attached to the plastic piece just removed. Remember its orientation for re-assembling later.
  3. Toshiba TDP-XP2 Fan Replacement: Schritt 3, Bild 1 von 3 Toshiba TDP-XP2 Fan Replacement: Schritt 3, Bild 2 von 3 Toshiba TDP-XP2 Fan Replacement: Schritt 3, Bild 3 von 3
    • Remove the screws from the case located around the device.
  4. Toshiba TDP-XP2 Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the plastic panels from the body.
  5. Toshiba TDP-XP2 Fan Replacement: Schritt 5, Bild 1 von 3 Toshiba TDP-XP2 Fan Replacement: Schritt 5, Bild 2 von 3 Toshiba TDP-XP2 Fan Replacement: Schritt 5, Bild 3 von 3
    • Remove the screws from the IO panel.
    • Pull up on the panel and remove it.
  6. Toshiba TDP-XP2 Fan Replacement: Schritt 6, Bild 1 von 2 Toshiba TDP-XP2 Fan Replacement: Schritt 6, Bild 2 von 2
    • Unscrew the screws from the metal shielding to remove it.
  7. Toshiba TDP-XP2 Fan Replacement: Schritt 7, Bild 1 von 3 Toshiba TDP-XP2 Fan Replacement: Schritt 7, Bild 2 von 3 Toshiba TDP-XP2 Fan Replacement: Schritt 7, Bild 3 von 3
    • Remove cables from motherboard.
    • Unscrew motherboard and remove from device.
  8. Toshiba TDP-XP2 Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove the cable from the bottom of the motherboard to fully remove it.
  9. Toshiba TDP-XP2 Fan Replacement: Schritt 9, Bild 1 von 1
    • Unscrew the power adapter on the back.
  10. Toshiba TDP-XP2 Fan Replacement: Schritt 10, Bild 1 von 2 Toshiba TDP-XP2 Fan Replacement: Schritt 10, Bild 2 von 2
    • Remove cables from the power supply board.
    • Remove the screws located around the board to un-mount it.
  11. Toshiba TDP-XP2 Fan Replacement: Schritt 11, Bild 1 von 1
    • Remove the power board to reveal the bottom two screws to the fan.
    • Unscrew the fan and replace it with an equivalent one.
Abschluss
Bryan Underwood
697 Reputation
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 280
