Zum Hauptinhalt wechseln
HP Compaq 6510b CD Drive Replacement
Was du brauchst
  1. HP Compaq 6510b CD Drive Replacement, Battery: Schritt 1, Bild 1 von 2 HP Compaq 6510b CD Drive Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the computer over so the backside is facing you.
    • Using the two prongs that are located in the back, slide the further left prong and the upper right prong to the left as indicated in the image.
    • Slide the battery out.
  2. HP Compaq 6510b CD Drive Replacement, Fan: Schritt 2, Bild 1 von 1
    • Look for tabs in between esc and f1, f4 and f5, f8 and f9, f12 and scroll.
    • Pull these tabs towards you.
  3. HP Compaq 6510b CD Drive Replacement: Schritt 3, Bild 1 von 2 HP Compaq 6510b CD Drive Replacement: Schritt 3, Bild 2 von 2
    • Flip the laptop over and on the back of the center of the keyboard there is a screw with a rectangle beside it that looks like a keyboard. Remove this Phillips 5mm screw and another similar screw in the back top left of the keyboard.
    • Then carefully lift the keyboard out of place with your fingernails or a plastic opening tool.
  4. HP Compaq 6510b CD Drive Replacement: Schritt 4, Bild 1 von 3 HP Compaq 6510b CD Drive Replacement: Schritt 4, Bild 2 von 3 HP Compaq 6510b CD Drive Replacement: Schritt 4, Bild 3 von 3
    • There will be a metallic film attached to the keyboard from the motherboard. A black latch runs along the film keeping it in place. Lift the latch and detach the film; remove it to fully remove the keyboard.
  5. HP Compaq 6510b CD Drive Replacement: Schritt 5, Bild 1 von 3 HP Compaq 6510b CD Drive Replacement: Schritt 5, Bild 2 von 3 HP Compaq 6510b CD Drive Replacement: Schritt 5, Bild 3 von 3
    • Carefully undo the white film the same way you took out the metallic film
    • Once this film is removed the bar with the power button and media tools above the keyboard will pop out of place using a spudger.
  6. HP Compaq 6510b CD Drive Replacement: Schritt 6, Bild 1 von 2 HP Compaq 6510b CD Drive Replacement: Schritt 6, Bild 2 von 2
    • Underneath, a metal clamp will be revealed with two Torx Security T7 17mm screws. Unscrew these.
    • Carefully lift the cable out of place that is to the right of it.
  7. HP Compaq 6510b CD Drive Replacement: Schritt 7, Bild 1 von 2 HP Compaq 6510b CD Drive Replacement: Schritt 7, Bild 2 von 2
    • Unscrew these two JIS #1 5mm screws on the fan.
    • Carefully unplug the fans' wires.
    • Remove the fan and put in new one.
  8. HP Compaq 6510b CD Drive Replacement, CD Drive: Schritt 8, Bild 1 von 3 HP Compaq 6510b CD Drive Replacement, CD Drive: Schritt 8, Bild 2 von 3 HP Compaq 6510b CD Drive Replacement, CD Drive: Schritt 8, Bild 3 von 3
    • Push the CD drive out using your finger.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Joseph Noudom
569 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S2-G5, Simcock Spring 2018 Mitglied von UMass Dartmouth, Team S2-G5, Simcock Spring 2018
UMASSD-SIMCOCK-S18S2G5
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
I don’t know why these instructions are suggested but this is how you actually remove the disc drive. https://www.youtube.com/watch?v=gTvAt3Nn...
Cretien - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 14
Insgesamt: 541
