Zum Hauptinhalt wechseln
Was du brauchst
Dieser Teardown ist keine Reparaturanleitung. Um dein NBC Kentucky Derby Brooch zu reparieren, verwende unsere Fehlerbehebungsseite.
  1. NBC Kentucky Derby  Brooch Teardown, Assemble Horse: Schritt 1, Bild 1 von 3 NBC Kentucky Derby  Brooch Teardown, Assemble Horse: Schritt 1, Bild 2 von 3 NBC Kentucky Derby  Brooch Teardown, Assemble Horse: Schritt 1, Bild 3 von 3
    • Gather all components and flip everything over.
    • Mount the head, tail, and both legs by placing them over their pivot points.
  2. NBC Kentucky Derby  Brooch Teardown, Attach linkage: Schritt 2, Bild 1 von 3 NBC Kentucky Derby  Brooch Teardown, Attach linkage: Schritt 2, Bild 2 von 3 NBC Kentucky Derby  Brooch Teardown, Attach linkage: Schritt 2, Bild 3 von 3
    • Carefully align the linkage with the mounting holes on both legs.
    • Place two 3mm eyeglass screws into either end of the linkage.
    • Tighten the screws. These screws will self-tap into the legs. Be careful to not over-tighten and seize the linkage.
  3. NBC Kentucky Derby  Brooch Teardown, Mount servo: Schritt 3, Bild 1 von 3 NBC Kentucky Derby  Brooch Teardown, Mount servo: Schritt 3, Bild 2 von 3 NBC Kentucky Derby  Brooch Teardown, Mount servo: Schritt 3, Bild 3 von 3
    • Pull the servo through the donut hole of the PCB (top to bottom).
    • Orient the servo arm to the left (aligned with the rest of the body). This represents the zero degree location.
    • Manually move the servo arm down 90 degrees so it is now points downward into the work surface.
    • Mount the servo to the enclosure.
  4. NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: Schritt 4, Bild 1 von 3 NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: Schritt 4, Bild 2 von 3 NBC Kentucky Derby  Brooch Teardown, Assemble enclosure: Schritt 4, Bild 3 von 3
    • Place the PCB overtop the servo.
    • Route the servo's wire around various components as depicted.
    • Coil extra wire in available space.
  5. NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: Schritt 5, Bild 1 von 3 NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: Schritt 5, Bild 2 von 3 NBC Kentucky Derby  Brooch Teardown, Mount horse to enclosure: Schritt 5, Bild 3 von 3
    • Align the enclosure with the mounting holes on the backside of the horse's body.
    • Align servo arm with the drive gap in the linkage. Double check this correct before tightening.
    • Use two M2 screws to attach the horse to the enclosure.
  6. NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: Schritt 6, Bild 1 von 3 NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: Schritt 6, Bild 2 von 3 NBC Kentucky Derby  Brooch Teardown, Assemble back of enclosure: Schritt 6, Bild 3 von 3
    • Start by placing the bottom notched-side into the lip of the enclosure.
    • Align all three mounting holes from above.
    • Press firmly with both hands (avoid putting pressure on horse) and work your hands around the edges until the back is pressed flush.
    • Secure the back of the enclosure by driving three M2 screws into place. DO NOT OVER TIGHTEN!
  7. NBC Kentucky Derby  Brooch Teardown, Give it power: Schritt 7, Bild 1 von 2 NBC Kentucky Derby  Brooch Teardown, Give it power: Schritt 7, Bild 2 von 2
    • Attach wiring harness to brooch.
    • Plug wiring harness into USB power supply.
Justin Sinichko
165 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 970
