Zum Hauptinhalt wechseln
ZTE ZMax Pro Motherboard Replacement
Was du brauchst
  1. ZTE ZMax Pro Motherboard Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Motherboard Replacement: Schritt 3, Bild 1 von 2 ZTE ZMax Pro Motherboard Replacement: Schritt 3, Bild 2 von 2
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Motherboard Replacement: Schritt 6, Bild 1 von 2 ZTE ZMax Pro Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
  9. ZTE ZMax Pro Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 2 ZTE ZMax Pro Motherboard Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Use the tweezers to peel off the yellow Kapton tape.
  10. ZTE ZMax Pro Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Use the plastic opening tool to remove the connectors on the motherboard.
  11. ZTE ZMax Pro Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Use tweezers to remove the antenna. The antenna comes up on the right side of the phone, by the battery, and is attached to the motherboard.
  12. ZTE ZMax Pro Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Using the #00 Phillips screwdriver, remove the 3.0 mm screw located on the right edge of the phone, above the battery.
  13. ZTE ZMax Pro Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Wedge the plastic opening tool underneath the motherboard which is located at the top of the phone.
    • Push down on the plastic opening tool, lifting the motherboard away from the phone.
    • Continue to do this around all sides of the motherboard until it is fully removed from the phone.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Nicholas Leacox
1.721 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S17-G3, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 1,583
