Zum Hauptinhalt wechseln
Cuisinart CHW-12 Heating Coil Replacement
Was du brauchst
  1. Cuisinart CHW-12 Heating Coil Replacement, Heating Coil: Schritt 1, Bild 1 von 2 Cuisinart CHW-12 Heating Coil Replacement, Heating Coil: Schritt 1, Bild 2 von 2
    • Unplug the coffee-maker from the power source.
    • Use a Phillips head screwdriver to remove the four 7mm screws from the back and the three 8mm screws from the bottom. This will release the bottom cover.
  2. Cuisinart CHW-12 Heating Coil Replacement: Schritt 2, Bild 1 von 2 Cuisinart CHW-12 Heating Coil Replacement: Schritt 2, Bild 2 von 2
    • Use tweezers to remove the two rubber feet marked within the provided pictures.
    • Remove both 8mm Phillips head screws found within the holes where the feet were just removed.
  3. Cuisinart CHW-12 Heating Coil Replacement: Schritt 3, Bild 1 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 3, Bild 2 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 3, Bild 3 von 3
    • Carefully pull the cover off the bottom of the coffee maker. This will give you access to the inside of the coffee maker.
    • Pull the gray ribbon cable strait out of the black containment box.
  4. Cuisinart CHW-12 Heating Coil Replacement: Schritt 4, Bild 1 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 4, Bild 2 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 4, Bild 3 von 3
    • Locate the Phillips head screws holding the highlighted plastic shield in place.
    • Remove the two 14mm screws with a Phillips head screwdriver.
    • Carefully slide the shield out of place along the power cord and set it aside.
  5. Cuisinart CHW-12 Heating Coil Replacement: Schritt 5, Bild 1 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 5, Bild 2 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 5, Bild 3 von 3
    • Remove the two 14mm Phillips head screws securing the plastic containment box.
    • Pull the plastic containment box straight out of the coffee maker.
  6. Cuisinart CHW-12 Heating Coil Replacement: Schritt 6, Bild 1 von 2 Cuisinart CHW-12 Heating Coil Replacement: Schritt 6, Bild 2 von 2
    • Remove the four 11mm Phillips head screws in each corner of the plastic containment box.
    • Pull the top from the plastic housing.
    • Lift the circuit board out of the plastic housing and set it aside until a latter step.
  7. Cuisinart CHW-12 Heating Coil Replacement: Schritt 7, Bild 1 von 2 Cuisinart CHW-12 Heating Coil Replacement: Schritt 7, Bild 2 von 2
    • Remove the two 14mm Phillips head screws that hold the heating coil in place.
  8. Cuisinart CHW-12 Heating Coil Replacement: Schritt 8, Bild 1 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 8, Bild 2 von 3 Cuisinart CHW-12 Heating Coil Replacement: Schritt 8, Bild 3 von 3
    • Pull back each hose clamp so that it no longer holds the hose on the heating coil.
    • After the clamps are released pull both hoses off the ends of the heating coil.
    • Set the coil aside.
  9. Cuisinart CHW-12 Heating Coil Replacement: Schritt 9, Bild 1 von 2 Cuisinart CHW-12 Heating Coil Replacement: Schritt 9, Bild 2 von 2
    • De-solder each of the four wires connecting the coil to the circuit board.
    • Solder iron can cause burns if used improperly.
    • When soldering the new wires in place make sure they are placed in the same holes the corresponding wires were taken out of.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Houston State, Team S17-G2, Blackburne Spring 2018 Mitglied von Sam Houston State, Team S17-G2, Blackburne Spring 2018
SHSU-BLACKBURNE-S18S17G2
3 Mitglieder
4 Anleitungen geschrieben
5 Kommentare
Unfortunately replacement heater tubes/coil do not seem to be available. If anyone has a link please share.
Mine corroded through and leaks through a pinhole allowing water to flow all over the counter.
dosman_5150 - Antwort
My Cuisinart chw-12 coffee pot came from a local hospital who had decided to throw it away after many years of use due to a small leak that has worsened over time. I figured I could save it, and after removing bottom cover, I discovered that there is a small pinhole link on the side of heating element due to rust and corrosion, with another forming right next to it. Hope I can find another heating element like this one!!
roj8706 - Antwort
I need a replacement heating element for this model, CHW-12. where can I find and purchase a new one from?
lenmalak@verizon.net
lenmalak - Antwort
This is our third one and they have all stopped making water hot on the right side but still make the coffee just fine. I threw the first two away but this one is only 7 months old and quit already. How can I fix the hot water maker? Can anyone send me some advice on this?
rpdfire1@sbcglobal.net
Ted G Ruys - Antwort
cant say yall will at this time, of posting, find the neededed parts, or if they are still needed but i thought id add this comment here for anyone else looking for parts,
ebay, search (your model coffee brewing machine) include "parts" with model number in search bar hit enter
or and
there may be some small appliance repair websites like "sears parts direct " or somethiing like that or similar to that on the web (the same or similar retail locations that youd take your vacuum to to get repaired, (dont take it to a vscuum only re0pair shop, but a place that does small appliance and vacuum repai locally or google parts for my model# coffee maker
the dude - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 17
Insgesamt: 2,796
