Zum Hauptinhalt wechseln
RedOctane X-Plorer Rear Case Replacement
Was du brauchst
  1. RedOctane X-Plorer Rear Case Replacement, Rear Case: Schritt 1, Bild 1 von 2 RedOctane X-Plorer Rear Case Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Rear Case Replacement: Schritt 2, Bild 1 von 3 RedOctane X-Plorer Rear Case Replacement: Schritt 2, Bild 2 von 3 RedOctane X-Plorer Rear Case Replacement: Schritt 2, Bild 3 von 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Rear Case Replacement: Schritt 3, Bild 1 von 3 RedOctane X-Plorer Rear Case Replacement: Schritt 3, Bild 2 von 3 RedOctane X-Plorer Rear Case Replacement: Schritt 3, Bild 3 von 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
Abschluss
Riley
649 Reputation
7 Anleitungen geschrieben
Cal Poly, Team S17-G1, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G1, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G1
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 544
