Zum Hauptinhalt wechseln
RedOctane X-Plorer Whammy Bar Replacement
Was du brauchst
  1. RedOctane X-Plorer Whammy Bar Replacement, Rear Case: Schritt 1, Bild 1 von 2 RedOctane X-Plorer Whammy Bar Replacement, Rear Case: Schritt 1, Bild 2 von 2
    • Remove the strap by pulling it off of the mounts located on the body and neck.
  2. RedOctane X-Plorer Whammy Bar Replacement: Schritt 2, Bild 1 von 3 RedOctane X-Plorer Whammy Bar Replacement: Schritt 2, Bild 2 von 3 RedOctane X-Plorer Whammy Bar Replacement: Schritt 2, Bild 3 von 3
    • Remove the nine 12mm Phillips #1 screws around the perimeter of the case with a screwdriver.
    • Remove the two 15mm Phillips #1 screws connecting the body panel to the neck panel with a screwdriver.
    • These screws can also be Torx on some models.
    • Pull off the rear case.
  3. RedOctane X-Plorer Whammy Bar Replacement: Schritt 3, Bild 1 von 3 RedOctane X-Plorer Whammy Bar Replacement: Schritt 3, Bild 2 von 3 RedOctane X-Plorer Whammy Bar Replacement: Schritt 3, Bild 3 von 3
    • Remove the five 12mm Phillips #1 screws along the neck with a screwdriver.
    • Pull off the top shell of the neck to expose the internal features.
  4. RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: Schritt 4, Bild 1 von 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: Schritt 4, Bild 2 von 3 RedOctane X-Plorer Whammy Bar Replacement, Whammy Bar: Schritt 4, Bild 3 von 3
    • Remove the two 7mm Phillips #2 screws from the black wire retainer.
    • Pull off the black wire retainer.
  5. RedOctane X-Plorer Whammy Bar Replacement: Schritt 5, Bild 1 von 1
    • Reach one finger under the guitar to push the whammy bar and its attached components from the case.
  6. RedOctane X-Plorer Whammy Bar Replacement: Schritt 6, Bild 1 von 2 RedOctane X-Plorer Whammy Bar Replacement: Schritt 6, Bild 2 von 2
    • Remove both of the plastic side tabs by gently pulling them off.
  7. RedOctane X-Plorer Whammy Bar Replacement: Schritt 7, Bild 1 von 1
    • Remove the two plastic tabs from the whammy bar casing.
    • Keep the spring connected to the plastic tabs throughout this step.
  8. RedOctane X-Plorer Whammy Bar Replacement: Schritt 8, Bild 1 von 1
    • Using two hands, remove the spring from the plastic tabs.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
[deleted]
175 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 13
Letzte 7 Tage: 29
Letzte 30 Tage: 102
Insgesamt: 3,600
