Zum Hauptinhalt wechseln
Sony Xperia XA Loudspeaker Replacement
Was du brauchst
  1. Sony Xperia XA Loudspeaker Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Apply heat on the back surface of the phone.
    • Continue to heat the device as needed throughout the replacement process.
    • The device can get very hot, so be careful when handling it.
  2. Sony Xperia XA Loudspeaker Replacement: Schritt 2, Bild 1 von 1
    • Stick the small suction cup on the bottom half of the back surface of the phone.
  3. Sony Xperia XA Loudspeaker Replacement: Schritt 3, Bild 1 von 3 Sony Xperia XA Loudspeaker Replacement: Schritt 3, Bild 2 von 3 Sony Xperia XA Loudspeaker Replacement: Schritt 3, Bild 3 von 3
    • With the bottom of the device facing you, lift up on the suction cup handle.
    • Use the plastic opening tool around all sides to pry off the back cover.
  4. Sony Xperia XA Loudspeaker Replacement: Schritt 4, Bild 1 von 3 Sony Xperia XA Loudspeaker Replacement: Schritt 4, Bild 2 von 3 Sony Xperia XA Loudspeaker Replacement: Schritt 4, Bild 3 von 3
    • Pull the back of the phone case away from the device.
    • You will hear popping sounds of glue being ripped from the phone.
    • You will hear the sound of the back unlatching from the device.
    • You will need to apply adhesive or glue along the device to have maximum seal in reassembly.
    • RAF antenna may be attached to the back cover upon removal.
  5. Sony Xperia XA Loudspeaker Replacement: Schritt 5, Bild 1 von 1
    • Apply heat to the copper RAF antenna.
    • This step and the following step only apply if the RAF antenna does not come off when taking the back cover off.
  6. Sony Xperia XA Loudspeaker Replacement: Schritt 6, Bild 1 von 1
    • Peel back the RAF antenna.
  7. Sony Xperia XA Loudspeaker Replacement, Loudspeaker: Schritt 7, Bild 1 von 2 Sony Xperia XA Loudspeaker Replacement, Loudspeaker: Schritt 7, Bild 2 von 2
    • Remove the four 4mm screws holding the loudspeaker in place with a Phillips #00 screwdriver.
  8. Sony Xperia XA Loudspeaker Replacement: Schritt 8, Bild 1 von 2 Sony Xperia XA Loudspeaker Replacement: Schritt 8, Bild 2 von 2
    • Push back the two retaining tabs on the top of the loudspeaker with the spudger.
  9. Sony Xperia XA Loudspeaker Replacement: Schritt 9, Bild 1 von 1
    • Pry the loudspeaker up with the spudger.
  10. Sony Xperia XA Loudspeaker Replacement: Schritt 10, Bild 1 von 1
    • Remove the loudspeaker with your hands.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Stephen Rock
230 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G2, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G2, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G2
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 490
