Einleitung
This guide will go over how to remove the two small speakers from the device.
Was du brauchst
Remove the four 15.5 mm PH2 screws securing the base plate to the device.
Remove the six 15.5mm PH2 screws securing the grille and rear panel to the device.
Remove the grille and rear panel by grabbing the corners and pulling upwards and outwards.
Disconnect the three cables from the power supply by squeezing the white tabs if present and gently pulling.
Pick up the power supply and remove the fourth cable from the underside of the power supply.
Remove the power supply.
Remove the five 15.5 mm PH2 screws holding the motherboard down.
Remove the three cables from the side of the motherboard by squeezing the grey tabs if present and gently pulling.
Remove the motherboard.
Remove the eight 15.5 mm PH2 screws holding the plastic insert down.
Remove the plastic insert and set it to the side.
Remove the three 15.5 mm PH2 screws holding the metal insert down.
Remove the metal insert and set it to the side.
Remove the six 15.5 mm PH2 screws securing the side plates to the front of the device.
Remove the six 15.5 mm PH2 screws securing the side plates to the back of the device.
Lay the device on its back and remove the four 11 mm PH0 screws holding the speaker to the device.
Remove the four 11 mm PH0 from the other speaker as well.
Remove the speakers from their housings, making sure to be careful with the wires.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
