Zum Hauptinhalt wechseln
LG X Style Camera Flash Replacement
Was du brauchst
  1. LG X Style Camera Flash Replacement, Battery: Schritt 1, Bild 1 von 1
    • Power down the device and make sure that it is turned off.
    • Insert the plastic opening tool into the bracket space on the back bottom left of the phone.
    • Gently twist tool clockwise until the back case pops open [this will create a small gap].
    • Slide the tool along the gap around the entire device.
  2. LG X Style Camera Flash Replacement: Schritt 2, Bild 1 von 2 LG X Style Camera Flash Replacement: Schritt 2, Bild 2 von 2
    • Insert the plastic opening tool into the indent below the battery, and pry up to lift and remove the battery.
  3. LG X Style Camera Flash Replacement, Screen: Schritt 3, Bild 1 von 2 LG X Style Camera Flash Replacement, Screen: Schritt 3, Bild 2 von 2
    • With a Phillips #000 screwdriver, remove the twelve 3mm screws.
  4. LG X Style Camera Flash Replacement: Schritt 4, Bild 1 von 3 LG X Style Camera Flash Replacement: Schritt 4, Bild 2 von 3 LG X Style Camera Flash Replacement: Schritt 4, Bild 3 von 3
    • Create a gap with plastic opening tool by applying pressure between glass screen and plastic edge of device.
    • Slide prying tool around entire device beginning toward the top.
    • Lift off and remove the screen from the device.
  5. LG X Style Camera Flash Replacement, Camera Flash: Schritt 5, Bild 1 von 2 LG X Style Camera Flash Replacement, Camera Flash: Schritt 5, Bild 2 von 2
    • Using a plastic opening tool, lift up display connection until disconnected from the lower right hand of the phone.
    • Carefully lift the metal connection perpendicular to the mother board.
  6. LG X Style Camera Flash Replacement: Schritt 6, Bild 1 von 2 LG X Style Camera Flash Replacement: Schritt 6, Bild 2 von 2
    • Gently lift the camera ribbon cable until the entire front camera housing is removed.
  7. LG X Style Camera Flash Replacement: Schritt 7, Bild 1 von 3 LG X Style Camera Flash Replacement: Schritt 7, Bild 2 von 3 LG X Style Camera Flash Replacement: Schritt 7, Bild 3 von 3
    • Use the opening tool, gently pry up along the edge of the motherboard.
    • Gently pull up and remove the motherboard from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 278
