Zum Hauptinhalt wechseln
Toshiba Satellite C855-S5115 Cooling Fan Replacement
Was du brauchst
  1. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Battery: Schritt 1, Bild 2 von 2
    • Use two fingers to pull the ridged lock tabs on the bottom of the computer toward the edges. This will unlock the battery.
  2. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 2, Bild 1 von 1
    • Holding the left tab in place, use the groove located between the two tabs to pry the battery up and out.
  3. Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 1 von 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement, Cooling Fan: Schritt 3, Bild 2 von 2
    • Remove the ten 7mm Phillips screws located on the bottom of the laptop using the Phillips #1 screwdriver.
  4. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 4, Bild 1 von 2 Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 4, Bild 2 von 2
    • Remove the 7mm Phillips screw located on the easy access panel on the bottom of the laptop using a Phillips #1 screwdriver.
  5. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 5, Bild 1 von 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 5, Bild 2 von 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 5, Bild 3 von 3
    • Insert a plastic opening tool and follow the edges to open the panel.
  6. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 3.5mm Phillips #1 screws indicated in the picture.
  7. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 7, Bild 1 von 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 7, Bild 2 von 3 Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 7, Bild 3 von 3
    • Remove the 3mm Phillips #1 screw holding the HDD in place, then slide the HDD towards the sticker.
  8. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 8, Bild 1 von 1
    • Pull the HDD out.
  9. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 9, Bild 1 von 1
    • Insert a plastic opening tool in between the panel and the main assembly.
  10. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 10, Bild 1 von 1
    • Work your way around the laptop to remove the base plate.
  11. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 11, Bild 1 von 1
    • Remove the single 1.5mm Phillips #1 screw located next to the cooling fan.
  12. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 12, Bild 1 von 1
    • Gently pull out the two pin connector.
  13. Toshiba Satellite C855-S5115 Cooling Fan Replacement: Schritt 13, Bild 1 von 1
    • Remove the CPU fan.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 1,468
