Zum Hauptinhalt wechseln
Infinity IT-8500 Massage Mechanism Replacement
Was du brauchst
  1. Infinity IT-8500 Massage Mechanism Replacement, Massage Mechanism: Schritt 1, Bild 1 von 3 Infinity IT-8500 Massage Mechanism Replacement, Massage Mechanism: Schritt 1, Bild 2 von 3 Infinity IT-8500 Massage Mechanism Replacement, Massage Mechanism: Schritt 1, Bild 3 von 3
    • The back cover is covered by this leather cover. which unzips easily.
    • Zipper is located here and there are 2 of these on either side.
  2. Infinity IT-8500 Massage Mechanism Replacement: Schritt 2, Bild 1 von 2 Infinity IT-8500 Massage Mechanism Replacement: Schritt 2, Bild 2 von 2
    • Remove all 6 screws
  3. Infinity IT-8500 Massage Mechanism Replacement: Schritt 3, Bild 1 von 2 Infinity IT-8500 Massage Mechanism Replacement: Schritt 3, Bild 2 von 2
    • At this point you should have the speakers dismounted and armrests unlatched.
    • Press Down on Latch between armrest and chair body .
    • What the result should look like.
  4. Infinity IT-8500 Massage Mechanism Replacement: Schritt 4, Bild 1 von 2 Infinity IT-8500 Massage Mechanism Replacement: Schritt 4, Bild 2 von 2
    • Remove all 12 screws from the frame.
  5. Infinity IT-8500 Massage Mechanism Replacement: Schritt 5, Bild 1 von 3 Infinity IT-8500 Massage Mechanism Replacement: Schritt 5, Bild 2 von 3 Infinity IT-8500 Massage Mechanism Replacement: Schritt 5, Bild 3 von 3
    • Note the speaker bracket will need be threaded through its leather slot and left hanging inside the back of the chair.
    • Next you will need to remove the leather from the Posts . To do this simply pull the leather over each post.
  6. Infinity IT-8500 Massage Mechanism Replacement: Schritt 6, Bild 1 von 1
    • The chair piece should separate from the frame with ease , should not have to force it . See previous step
    • From here that chair piece should hold itself up while you remove that mechanism.
  7. Infinity IT-8500 Massage Mechanism Replacement: Schritt 7, Bild 1 von 2 Infinity IT-8500 Massage Mechanism Replacement: Schritt 7, Bild 2 von 2
    • Now we need to disconnect the wire harness from the mechanism . Do this by simply unplugging the marked cables
  8. Infinity IT-8500 Massage Mechanism Replacement, Wire harness: Schritt 8, Bild 1 von 3 Infinity IT-8500 Massage Mechanism Replacement, Wire harness: Schritt 8, Bild 2 von 3 Infinity IT-8500 Massage Mechanism Replacement, Wire harness: Schritt 8, Bild 3 von 3
    • ONLY FOLLOW THIS STEP AND THE NEXT IF YOU ARE REPLACING THE ENTIRE WIRE HARNESS IF NOT THEN SKIP THIS AND STEP 9.
    • When replacing the wire harness you need to disconnect the upper portion of the harness from the mechanism and then locate the quick disconnect .
    • Quick disconnect
  9. Infinity IT-8500 Massage Mechanism Replacement, Wire Harness: Schritt 9, Bild 1 von 3 Infinity IT-8500 Massage Mechanism Replacement, Wire Harness: Schritt 9, Bild 2 von 3 Infinity IT-8500 Massage Mechanism Replacement, Wire Harness: Schritt 9, Bild 3 von 3
    • This step will show you where the wires are for the lower portion of the harness.
    • Remove the 3 screws
    • These are the locations of the the wires for the lower harness
  10. Infinity IT-8500 Massage Mechanism Replacement: Schritt 10, Bild 1 von 3 Infinity IT-8500 Massage Mechanism Replacement: Schritt 10, Bild 2 von 3 Infinity IT-8500 Massage Mechanism Replacement: Schritt 10, Bild 3 von 3
    • Remove all 4 screws on top bar
  11. Infinity IT-8500 Massage Mechanism Replacement: Schritt 11, Bild 1 von 1
    • Next attach a flat head bit to a cordless drill and insert it into the the top of the Up and Down motor. this will allow you to drive the mechanism out the top of the track.
  12. Infinity IT-8500 Massage Mechanism Replacement: Schritt 12, Bild 1 von 1
    • ALL DONE!
Abschluss
Nick
2.737 Reputation
16 Anleitungen geschrieben
2 Kommentare
Anyone know the pin out on the 8-pin control panel dim? My pup chewed through it and of course It was thrown out ASAP.
Randy C - Antwort
Infinity IT 8500 Massage Chair Remote , Anyone know the pin out on the 8-pin control panel dim? My pup chewed through it and of course It was thrown out ASAP RandyC
Randy C - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 15
Letzte 30 Tage: 35
Insgesamt: 666
