Zum Hauptinhalt wechseln
Dell Inspiron 14 M4010 Memory Modules Replacement
  1. Dell Inspiron 14 M4010 Memory Modules Replacement, Popping up the Memory Module: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in Before You Begin.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • CAUTION: To prevent damage to the memory module connector, do not use tools to spread the memory module securing clips.
    • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the module pops up.
  2. Dell Inspiron 14 M4010 Memory Modules Replacement, Remove the Memory Module: Schritt 2, Bild 1 von 1
    • Remove the memory module from the memory-module connector.
    • CAUTION: If you need to install memory modules in two connectors, install a memory module in the connector labeled "DIMM A" before you install a memory module in the connector labeled "DIMM B."
  3. Dell Inspiron 14 M4010 Memory Modules Replacement, Align the Notch: Schritt 3, Bild 1 von 1
    • Align the notch in the NEW memory module with the tab in the memory-module connector.
  4. Dell Inspiron 14 M4010 Memory Modules Replacement, Installing the Memory Module: Schritt 4, Bild 1 von 1
    • Slide the memory module firmly into the slot at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
    • NOTE: If the memory module is not installed properly, the computer may not boot.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 36
