Zum Hauptinhalt wechseln
LG Neon II Battery Replacement
Was du brauchst
  1. LG Neon II Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • To gain access to the phone’s speaker, grip the phone firmly in an inverted position with the back of the unit facing up and the LG insignia positioned away from you.
    • Using both hands as support, use your thumbs to gently guide the rear housing away and in the direction of the arrow.
  2. LG Neon II Battery Replacement: Schritt 2, Bild 1 von 1
    • After removing the phone’s back-panel, securely cushion the front of the phone on a soft surface such as a cloth or your hand.
    • Gently insert a spudger under the lip of the battery, preferably the lip away from the camera eye.
    • Gently pry the battery out of its seated position.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sara
65 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 1-6, Propen Fall 2012 Mitglied von Cal Poly, Team 1-6, Propen Fall 2012
CPSU-PROPEN-F12S1G6
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 900
