Zum Hauptinhalt wechseln
HP Pavilion Sleekbook 14-b013cl Screen Replacement
Was du brauchst
  1. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: Schritt 1, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the computer over and move the battery lock switch to the "unlocked" position (marked by an orange lock icon).
  2. HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 2, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 2, Bild 2 von 2
    • Press the switch on the right-hand side of the back of the device towards the center until the gray battery icon is no longer visible. This will eject the battery.
  3. HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 3, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 3, Bild 2 von 2
    • Carefully pull the battery away from the device.
  4. HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: Schritt 4, Bild 1 von 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: Schritt 4, Bild 2 von 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement, Screen: Schritt 4, Bild 3 von 3
    • Using a 1.0 Flathead screwdriver, remove the two stickers covering the screws that hold the screen in place.
    • Use a Phillips #1 screwdriver to remove the two 3.2mm screws that are now visible.
  5. HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 5, Bild 1 von 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 5, Bild 2 von 3 HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 5, Bild 3 von 3
    • Using a plastic opening tool, pry the plastic screen protector off, sliding the tool along the seam. Press the tool in until you hear the plastic tabs clicking as they come undone.
    • Separate the plastic that makes up the hinges for the screen, as they are part of the same screen protector.
    • Use your hands or plastic tool to peel the screen protector away from the adhesive holding it in place.
  6. HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 6, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 6, Bild 2 von 2
    • Using a Phillips #1 screwdriver, remove the six 2.8mm screws holding the screen in place.
    • Lift the screen away from the cover until you have access to the connector cable near the bottom of the screen.
  7. HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 7, Bild 1 von 2 HP Pavilion Sleekbook 14-b013cl Screen Replacement: Schritt 7, Bild 2 von 2
    • Peel away any sticker holding the connector in place and simply pull the tab out of the connector parallel with the screen.
    • Remove the screen from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 445
