Zum Hauptinhalt wechseln
Samsung Galaxy Note5 Display Replacement
Was du brauchst
  1. Samsung Galaxy Note5 Display Replacement, SIM Card Tray: Schritt 1, Bild 1 von 1
    • Insert a SIM Ejector Tool into the small hole on the left side of the top edge of the device.
    • Press down until the SIM Card Tray begins to protrude out of the device.
  2. Samsung Galaxy Note5 Display Replacement: Schritt 2, Bild 1 von 1
    • Remove the SIM Card Tray from the slot.
  3. Samsung Galaxy Note5 Display Replacement, Display: Schritt 3, Bild 1 von 1
    • Heat the back of the device with a heat gun for two minutes.
  4. Samsung Galaxy Note5 Display Replacement: Schritt 4, Bild 1 von 1
    • Once the device is very warm to the touch, place a suction cup near the bottom of the back of the device.
    • Make sure to place the suction cup on the flat part of the glass.
    • Gently pull upwards on the suction cup to separate the rear glass from the body of the phone.
    • While pulling upwards, insert a pick under the rear glass
  5. Samsung Galaxy Note5 Display Replacement: Schritt 5, Bild 1 von 1
    • Keeping the pick under the rear glass, move the pick along the bottom edge of the device to cut the adhesive.
  6. Samsung Galaxy Note5 Display Replacement: Schritt 6, Bild 1 von 1
    • Repeat the previous heating and cutting procedure for the remaining three sides of the phone.
    • Leave a pick on each side as you continue to the next to prevent the adhesive from resealing.
  7. Samsung Galaxy Note5 Display Replacement: Schritt 7, Bild 1 von 1
    • Once all adhesive has been cut, gently lift up the rear glass to remove it.
  8. Samsung Galaxy Note5 Display Replacement: Schritt 8, Bild 1 von 1
    • Remove the S-Pen from the bottom of the device.
  9. Samsung Galaxy Note5 Display Replacement: Schritt 9, Bild 1 von 2 Samsung Galaxy Note5 Display Replacement: Schritt 9, Bild 2 von 2
    • Remove 20 5mm screws with a Phillips #1 Screwdriver.
  10. Samsung Galaxy Note5 Display Replacement: Schritt 10, Bild 1 von 3 Samsung Galaxy Note5 Display Replacement: Schritt 10, Bild 2 von 3 Samsung Galaxy Note5 Display Replacement: Schritt 10, Bild 3 von 3
    • Grip the back of the device and press down on the white square to remove the middle housing.
  11. Samsung Galaxy Note5 Display Replacement: Schritt 11, Bild 1 von 1
    • Loosen the two signal cable connectors.
  12. Samsung Galaxy Note5 Display Replacement: Schritt 12, Bild 1 von 3 Samsung Galaxy Note5 Display Replacement: Schritt 12, Bild 2 von 3 Samsung Galaxy Note5 Display Replacement: Schritt 12, Bild 3 von 3
    • To disconnect flexes, carefully pull up on the exposed tab with tweezers.
    • Disconnect the battery flex.
    • Disconnect the earpiece flex.
  13. Samsung Galaxy Note5 Display Replacement: Schritt 13, Bild 1 von 1
    • Remove the teal navigation button flex.
  14. Samsung Galaxy Note5 Display Replacement: Schritt 14, Bild 1 von 1
    • Gently lift up the motherboard from the top end to remove.
    • Make sure all flexes are disconnected before removing the motherboard. If the motherboard does not easily detach, remove any connected flexes.
  15. Samsung Galaxy Note5 Display Replacement: Schritt 15, Bild 1 von 3 Samsung Galaxy Note5 Display Replacement: Schritt 15, Bild 2 von 3 Samsung Galaxy Note5 Display Replacement: Schritt 15, Bild 3 von 3
    • With the motherboard removed, slowly pry off the battery with tweezers, starting at the bottom.
    • Be careful not to puncture the battery as this could cause permanent damage.
  16. Samsung Galaxy Note5 Display Replacement: Schritt 16, Bild 1 von 1
    • Heat the display for two minutes with a heat gun.
  17. Samsung Galaxy Note5 Display Replacement: Schritt 17, Bild 1 von 1
    • Once the display is very warm to the touch, slide a pick between the LCD and the LCD shield on the bottom edge of the device.
    • Slide the pick across the bottom to cut through the adhesive.
  18. Samsung Galaxy Note5 Display Replacement: Schritt 18, Bild 1 von 1
    • The display is now removed.
Abschluss
37 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team S25-G17, Maness Spring 2018 Mitglied von Cal Poly, Team S25-G17, Maness Spring 2018
CPSU-MANESS-S18S25G17
4 Mitglieder
5 Anleitungen geschrieben
6 Kommentare
Worked like a charm
Ronald Sapp - Antwort
How does one bond everything back together?
lcplthomasc - Antwort
I am working in fixing my own Note 5. I have heard that double-sided tape made specifically for this task are best. You can find different options here: https://www.magazingsm.ro/adeziv-geam-si...
Cristina -
I have now replaced the display on my Note 5 and actually I didn’t even use the glue I bought. The original glue is quite a lot and the new display comes with glue on the back of it. Thanks again, Alexander, for your helpful instructions!
Cristina -
This was very helpful. Many thanks to the author. may God add many years to his life.
Peterson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 26
Letzte 30 Tage: 114
Insgesamt: 23,956
