Zum Hauptinhalt wechseln
Sanitaire SC684 Roller Brusher and Drive Belt Replacement
  1. Sanitaire SC684 Roller Brusher and Drive Belt Replacement, Roller Brush and Belt: Schritt 1, Bild 1 von 1
    • Be sure to unplug the vacuum cleaner before disassembling to prevent electric shock.
    • Lay the vacuum on its back.
  2. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: Schritt 2, Bild 1 von 1
    • Find the metal plate (located directly in the center).
    • Locate the two latches on either side of the metal plate.
    • Detach the latches by pulling them away from metal plate.
  3. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: Schritt 3, Bild 1 von 1
    • Remove the metal plate by pulling it towards you.
  4. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: Schritt 4, Bild 1 von 1
    • Identify the belt and brush roller.
    • The belt is a black ring made of rubber.
    • The brush roller is the long metal tube with bristles attached to it.
  5. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: Schritt 5, Bild 1 von 1
    • Remove the belt from the circular knob by inserting your fingers on either side, gently lifting towards you.
  6. Sanitaire SC684 Roller Brusher and Drive Belt Replacement: Schritt 6, Bild 1 von 2 Sanitaire SC684 Roller Brusher and Drive Belt Replacement: Schritt 6, Bild 2 von 2
    • Pull brush roller out and slip the belt off from the indent in the middle of the roller.
Abschluss
Caycie Pascual
1 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 16-58, Forte Fall 2012 Mitglied von Cal Poly, Team 16-58, Forte Fall 2012
CPSU-FORTE-F12S16G58
5 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 18
Insgesamt: 2,803
