Zum Hauptinhalt wechseln
Nook Tablet Back Cover Replacement
Was du brauchst
  1. Nook Tablet Back Cover Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Flip the Nook over.
  2. Nook Tablet Back Cover Replacement: Schritt 2, Bild 1 von 2 Nook Tablet Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Lift the flap that reads "Nook" to reveal the tape that is underneath. Remove the memory card if one is present.
    • Remove the tape covering the round holes to reveal two T5 Torx screws.
    • Remove the two T5 Torx screws securing the back cover.
  3. Nook Tablet Back Cover Replacement: Schritt 3, Bild 1 von 2 Nook Tablet Back Cover Replacement: Schritt 3, Bild 2 von 2
    • Insert the flat end of a spudger between the front panel and the rear assembly.
    • Though these photos show a screwdriver, use a spudger or plastic opening tool in order to prevent damage to the device.
    • Use a spudger to lift the the back panel from the rest of the Nook.
  4. Nook Tablet Back Cover Replacement: Schritt 4, Bild 1 von 2 Nook Tablet Back Cover Replacement: Schritt 4, Bild 2 von 2
    • Slide the spudger around the edges of the Nook to loosen the back panel.
  5. Nook Tablet Back Cover Replacement: Schritt 5, Bild 1 von 1
    • Pull the back panel off the Nook.
Abschluss
To reassemble your device, line up the piece that was removed with how it was on before and then just firmly press down till it snaps into place.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 1-4, Propen Fall 2012 Mitglied von Cal Poly, Team 1-4, Propen Fall 2012
CPSU-PROPEN-F12S1G4
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 5,859
