Zum Hauptinhalt wechseln
Dell Inspiron 15 7579 RAM (Memory) Replacement
Was du brauchst
  1. Dell Inspiron 15 7579 RAM (Memory) Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the ten 7.9 mm screws with the Phillips PH0 screwdriver.
  2. Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 2, Bild 1 von 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 2, Bild 2 von 2
    • Insert metal spudger into a gap in between the back panel and the back of the screen.
    • Pry off the back panel using the metal spudger as a lever, and remove the back panel by lifting the rest off by hand.
  3. Dell Inspiron 15 7579 RAM (Memory) Replacement, RAM (Memory): Schritt 3, Bild 1 von 1
    • Fold protective flaps to the side on the RAM module located in the upper right corner of the laptop.
  4. Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 4, Bild 1 von 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 4, Bild 2 von 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 4, Bild 3 von 3
    • Use the tweezers to push the crimping metal away from the chip. The chip will pop up into an angled position.
    • Remove the chip by pulling at the same angle as the chip with the tweezers.
  5. Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 5, Bild 1 von 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 5, Bild 2 von 3 Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 5, Bild 3 von 3
    • Fold the plastic flap over on the other side.
    • As before, pull the fasteners away from the chip with the tweezers.
    • Remove the chip by carefully pulling it out with the tweezers.
  6. Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 6, Bild 1 von 2 Dell Inspiron 15 7579 RAM (Memory) Replacement: Schritt 6, Bild 2 von 2
    • When reassembling, you must match the notch in the card with the notch in the connector header shown in red.
    • Doing otherwise will break the stick if forced.
Abschluss
Cal Poly, Team S24-G9, Maness Spring 2018 Mitglied von Cal Poly, Team S24-G9, Maness Spring 2018
CPSU-MANESS-S18S24G9
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 684
