Einleitung
This guide is intended to show how to remove a damaged screen from the laptop. Reversing the steps will describe the steps needed to replace the laptop with a new screen.
Was du brauchst
Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
Un-clip both wire clips on the upper and right side of the battery.
Lift the battery out of the device.
Use the metal spudger to gently lift the two plastic squares off the screen.
Use the plastic opening tool to pry the front edges of the screen off of the back.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
