Zum Hauptinhalt wechseln
Asus Q551L Repair Motherboard Replacement
Was du brauchst
  1. Asus Q551L Repair Motherboard Replacement, Back Panel: Schritt 1, Bild 1 von 2 Asus Q551L Repair Motherboard Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Unscrew the 10 screws around the edge of the back panel. Eight of the screws are 0.0793mm T5 , two of them are 0.0793 JIS #0.
  2. Asus Q551L Repair Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to pry the back panel off the base of the laptop.
  3. Asus Q551L Repair Motherboard Replacement, Battery: Schritt 3, Bild 1 von 2 Asus Q551L Repair Motherboard Replacement, Battery: Schritt 3, Bild 2 von 2
    • Unscrew the four screws to remove the battery.
  4. Asus Q551L Repair Motherboard Replacement: Schritt 4, Bild 1 von 2 Asus Q551L Repair Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Un-clip both wire clips on the upper and right side of the battery.
    • Lift the battery out of the device.
  5. Asus Q551L Repair Motherboard Replacement, Optical Drive: Schritt 5, Bild 1 von 3 Asus Q551L Repair Motherboard Replacement, Optical Drive: Schritt 5, Bild 2 von 3 Asus Q551L Repair Motherboard Replacement, Optical Drive: Schritt 5, Bild 3 von 3
    • Lift up the sticker that sticks between the motherboard and the optical drive. Then, unscrew the one screw where it is marked and slide it out gently.
    • Watch out for the wires around the optical drive.
  6. Asus Q551L Repair Motherboard Replacement, Motherboard: Schritt 6, Bild 1 von 3 Asus Q551L Repair Motherboard Replacement, Motherboard: Schritt 6, Bild 2 von 3 Asus Q551L Repair Motherboard Replacement, Motherboard: Schritt 6, Bild 3 von 3
    • Remove the fan by unscrewing the nine screws shown in the images.
    • The four colored wire and the black cable need to be pulled out gently.
    • There will be wires around the fan. Make sure they are not stuck to it.
    • You want to keep the fan if it still in good conditions.
  7. Asus Q551L Repair Motherboard Replacement: Schritt 7, Bild 1 von 2 Asus Q551L Repair Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the seven screws Phillips Head 0.0793 MM on the edges of the motherboard.
  8. Asus Q551L Repair Motherboard Replacement: Schritt 8, Bild 1 von 3 Asus Q551L Repair Motherboard Replacement: Schritt 8, Bild 2 von 3 Asus Q551L Repair Motherboard Replacement: Schritt 8, Bild 3 von 3
    • Disconnect any cables that hold the motherboard.
    • Open up the white adjustable latch first to pull out the tapes.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
Thanks for posting this guide. Helped me to fix this model computer for a friend. Very well done!
Robert Valentino - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 2,359
