Zum Hauptinhalt wechseln
Dell Inspiron 1410 Hard Drive Replacement
Was du brauchst
  1. Dell Inspiron 1410 Hard Drive Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • CAUTION: Before working inside your computer, read the safety information that shipped with your computer. Follow the procedures in Before You Begin.
    • CAUTION: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Remove the two screws securing the hard drive assembly to the system board.
  2. Dell Inspiron 1410 Hard Drive Replacement, Removing the Hard Drive Assembly: Schritt 2, Bild 1 von 1
    • Holding the connector end of the hard drive assembly, pull the hard drive assembly from the system board connector.
  3. Dell Inspiron 1410 Hard Drive Replacement, Removing the Hard Drive Cage: Schritt 3, Bild 1 von 1
    • Press down on the hard drive at the non-connector end slot to remove the hard drive off the hard drive cage.
  4. Dell Inspiron 1410 Hard Drive Replacement, Placing the Hard Drive: Schritt 4, Bild 1 von 1
    • Place the NEW hard drive in the hard drive cage and press it down until it snaps into place.
  5. Dell Inspiron 1410 Hard Drive Replacement, Aligning the Hard Drive: Schritt 5, Bild 1 von 1
    • Push down the hard drive assembly in place by aligning the hard drive connector with the system board connector.
  6. Dell Inspiron 1410 Hard Drive Replacement, Replace the Screws: Schritt 6, Bild 1 von 1
    • Replace the two screws securing the hard drive assembly to the system board.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 6
Insgesamt: 345
