Zum Hauptinhalt wechseln
LG G Pad X 8.3 Rear-facing camera Replacement
Was du brauchst
  1. LG G Pad X 8.3 Rear-facing camera Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove the cover of the SD card. Find it on the right side of the back of the tablet.
    • Press the SD card in to make it pop out.
  2. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 2, Bild 1 von 1
    • Slide the stylus out from the bottom left corner of the back panel.
  3. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 3, Bild 1 von 1
    • Start at a corner and pry the screen up with a plastic opening tool.
    • You can also use a plastic spudger for this task, but do not use metal tools. They can be dangerous to you and the device.
    • Slide the tool in the seam at the edge of the screen.
    • Wedge additional plastic opening tools in the seam to help lift the screen.
    • Slide both wedged plastic opening tools towards the bottom to pop the screen loose.
    • If your screen is cracked, work slowly to avoid flinging glass shards when prying.
  4. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 4, Bild 1 von 3 LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 4, Bild 2 von 3 LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 4, Bild 3 von 3
    • With a Phillips #000 screwdriver, unscrew the six 4.0 mm screws that hold down the battery.
    • With the Phillips #000 screwdriver, unscrew the two 4.0 mm screws that hold down the battery ribbon connector.
    • Use a magnetic mat to keep track of these tiny screws for later reassembly.
  5. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 5, Bild 1 von 1
    • Lift the battery ribbon connector with your finger.
  6. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery with your fingers and remove it from the device.
  7. LG G Pad X 8.3 Rear-facing camera Replacement, Speaker: Schritt 7, Bild 1 von 1
    • With a Phillips #000 screwdriver, unscrew the one 4.0 mm screw that is holding down the speaker.
    • Use the magnetic mat to keep track of the tiny screw(s).
  8. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 8, Bild 1 von 1
    • Lift and remove the speaker with your finger.
  9. LG G Pad X 8.3 Rear-facing camera Replacement, Motherboard: Schritt 9, Bild 1 von 2 LG G Pad X 8.3 Rear-facing camera Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • With the Phillips #000 screwdriver, unscrew the four 4.0 mm screw that are holding down the motherboard.
  10. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 10, Bild 1 von 2 LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 10, Bild 2 von 2
    • Use a plastic opening tool to lift up the ribbon connector at the bottom of the motherboard.
    • Only lift up the end of the ribbon connector that is attached to the motherboard. The end at the base of the tablet should stay attached.
  11. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 11, Bild 1 von 3 LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 11, Bild 2 von 3 LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 11, Bild 3 von 3
    • Lift and release the remaining ribbon connectors in the upper left corner of the motherboard with a plastic opening tool.
    • Avoid bending the tips of the ribbon connectors to prevent damage.
  12. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 12, Bild 1 von 2 LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 12, Bild 2 von 2
    • With your fingers, lift up the motherboard from the upper right corner.
    • Carefully remove the fragile motherboard from the device.
  13. LG G Pad X 8.3 Rear-facing camera Replacement, Rear-facing camera: Schritt 13, Bild 1 von 1
    • Insert the plastic opening tool under the ribbon connector that is holding the rear-facing camera down and lift it up.
  14. LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 14, Bild 1 von 2 LG G Pad X 8.3 Rear-facing camera Replacement: Schritt 14, Bild 2 von 2
    • After prying ribbon connector, the rear-facing camera should be ready for removal.
    • Gently lift the rear-facing camera with your fingers and remove.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 99
