Zum Hauptinhalt wechseln
HP Pavilion G6-1d16dx Motherboard Replacement
Was du brauchst
  1. HP Pavilion G6-1d16dx Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
  2. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Slide the switch under the battery compartment to release the battery.
  3. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery.
    • The battery will have popped out of the compartment when it was released.
  4. HP Pavilion G6-1d16dx Motherboard Replacement, Motherboard: Schritt 4, Bild 1 von 1
    • Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
    • The screws do not remove from the cover.
  5. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 5, Bild 1 von 2 HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 5, Bild 2 von 2
    • Unsnap the Cover by lifting the edge along the battery compartment.
    • Remove all of the body screws.
    • Remove the rubber cap and the screw underneath it.
  6. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 6, Bild 1 von 3 HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 6, Bild 2 von 3 HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 6, Bild 3 von 3
    • The keyboard is held in by nine tabs
    • Using a metal tool, depress the center tab and pry up the keyboard by pivoting the tool towards the screen.
  7. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 7, Bild 1 von 2 HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Slide the tool that is now under the keyboard sideways along the edge and use another tool to depress the other tabs along the edge of the keyboard.
    • As you depress the tabs, the edges of the keyboard will pop up.
    • Lift off the keyboard
  8. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Flip up the black tab holding the keyboard in place via the ribbon cable and pull out the cable
  9. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 9, Bild 1 von 3 HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 9, Bild 2 von 3 HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 9, Bild 3 von 3
    • Remove the two remaining ribbon cables.
    • Remove the screws holding in the protective cover underneath the keyboard.
    • Pop the cover off using any flat metal tool, starting with where you took out the optical drive
    • It will be very sticky near the edge closest to the screen. This is where the sticker in the battery compartment is stuck to. just use a little more force.
  10. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 10, Bild 1 von 1
    • Unplug the ribbon cable on the right side of the motherboard.
  11. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 11, Bild 1 von 2 HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Underneath the computer, unscrew the hard drive connector screw, and pop out the hard drive plug-in.
  12. HP Pavilion G6-1d16dx Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Unscrew all mother board screws and lift the motherboard out of the body.
    • For replacing the screen hinges and screen, skip this step
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 21
Insgesamt: 2,111
