Einleitung
This guide aims to teach you how to replace a motherboard, a necessary step if your computer has overheated and shorted the board. It is a fairly complex process, but through clean pictures and concise steps it should help guide you through the process.
Was du brauchst
Flip the computer so that the bottom side is facing up, and locate the battery above the screen hinges.
Unscrew the two silver screws holding the protective cover in place until they make a clicking noise.
Unsnap the Cover by lifting the edge along the battery compartment.
Remove all of the body screws.
Remove the rubber cap and the screw underneath it.
Using a metal tool, depress the center tab and pry up the keyboard by pivoting the tool towards the screen.
Slide the tool that is now under the keyboard sideways along the edge and use another tool to depress the other tabs along the edge of the keyboard.
Lift off the keyboard
Flip up the black tab holding the keyboard in place via the ribbon cable and pull out the cable
Remove the two remaining ribbon cables.
Remove the screws holding in the protective cover underneath the keyboard.
Pop the cover off using any flat metal tool, starting with where you took out the optical drive
Underneath the computer, unscrew the hard drive connector screw, and pop out the hard drive plug-in.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
