Zum Hauptinhalt wechseln
HP ProBook 4530s Hard Drive Replacement
Was du brauchst
  1. HP ProBook 4530s Hard Drive Replacement, Introduction: Schritt 1, Bild 1 von 2 HP ProBook 4530s Hard Drive Replacement, Introduction: Schritt 1, Bild 2 von 2
    • Start by flipping over the laptop onto its back.
  2. HP ProBook 4530s Hard Drive Replacement, Battery Removal: Schritt 2, Bild 1 von 2 HP ProBook 4530s Hard Drive Replacement, Battery Removal: Schritt 2, Bild 2 von 2
    • Press inward on the two switches.
    • The battery should pop out slightly.
    • Remove the battery.
  3. HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: Schritt 3, Bild 1 von 2 HP ProBook 4530s Hard Drive Replacement, Back Panel Removal: Schritt 3, Bild 2 von 2
    • Press inward on both switches while pushing the center panel away from you. It should slide slightly backwards.
    • Release the switches.
    • Slide the panel the rest of the way out.
  4. HP ProBook 4530s Hard Drive Replacement, Removing HDD: Schritt 4, Bild 1 von 2 HP ProBook 4530s Hard Drive Replacement, Removing HDD: Schritt 4, Bild 2 von 2
    • Unscrew the four screws located on the edges of the base.
    • Lift enough on the right side of the HDD to make it over the plastic paneling.
    • Pull outward.
  5. HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: Schritt 5, Bild 1 von 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: Schritt 5, Bild 2 von 3 HP ProBook 4530s Hard Drive Replacement, Removing HDD from Base: Schritt 5, Bild 3 von 3
    • Remove the adhesive from the protective covering over the HDD.
    • Remove the four screws around the edges of the metal base.
    • Pull out the HDD from the base.
  6. HP ProBook 4530s Hard Drive Replacement, Conclusion: Schritt 6, Bild 1 von 1
    • Insert the new HDD or SSD.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Drew Canada
1.370 Reputation
4 Anleitungen geschrieben
2 Kommentare
Clear and easy instructions. It’s nice to encounter a computer with such easy access to the internals.
Lensyl Urbano - Antwort
You have saved me time and money from going to my engineer to help me out. Thank you.
Mercy Ayinde - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 77
Insgesamt: 12,259
