Zum Hauptinhalt wechseln
Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement
Was du brauchst
  1. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: Schritt 1, Bild 1 von 2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, Hard Disk Drive: Schritt 1, Bild 2 von 2
    • Remove the 8 screws that hold down the back panel using the Phillips #000 screwdriver.
  2. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the two M2 x 3 mm, wafer-head, nylon-coated screws that hold down the hard drive assembly using the Phillips #0 screwdriver.
  3. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 3, Bild 1 von 1
    • Pull the hard drive assembly out with backside up.
  4. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 4, Bild 1 von 1
    • Remove the four M3 x 3 mm, flat-head, nylon-coated screws on the side of the hard drive assembly using the Phillips #0 screwdriver.
  5. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 5, Bild 1 von 1
    • Gently, remove the plastic cover with the blue strips.
  6. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: Schritt 6, Bild 1 von 2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement, HDMI-USB Jack assembly: Schritt 6, Bild 2 von 2
    • Remove the 3 screws holding down the T shaped cover using the Phillips head #1. Two of the screws are M2.5x 4 wafer head. The other is a M2x4MM.
    • The two similar screws have blue threading around them.
  7. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 7, Bild 1 von 2 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 7, Bild 2 von 2
    • Use the opening tool to lift up the T shaped cover.
    • Remove the M2x3MM wafer head screw.
  8. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 8, Bild 1 von 3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 8, Bild 2 von 3 Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 8, Bild 3 von 3
    • Take off the 2 M2x3MM wafered screws holding down the chip top of assembly.
    • Lift the chip to release the HDMI-USB jack assembly
  9. Lenovo ThinkPad S431 HDMI-USB Jack assembly Replacement: Schritt 9, Bild 1 von 1
    • Detach the connector.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 276
