Zum Hauptinhalt wechseln
Lenovo ThinkPad S431 Integrated Camera Replacement
Was du brauchst
  1. Lenovo ThinkPad S431 Integrated Camera  Replacement, Screen Assembly: Schritt 1, Bild 1 von 1
    • Place an opening tool under the screen cover, and pop it off.
    • Using a metal object to open fragile parts of your laptop could cause damage! Instead use the opening tool listed in the tools section above.
  2. Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 2, Bild 1 von 2 Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 2, Bild 2 von 2
    • Take off the 6 screws using the Philips head #1.
  3. Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 3, Bild 1 von 1
    • Lift the screen out from the top.
  4. Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 4, Bild 1 von 2 Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 4, Bild 2 von 2
    • Remove the connector located at the bottom of the back of the screen.
  5. Lenovo ThinkPad S431 Integrated Camera  Replacement, Integrated Camera: Schritt 5, Bild 1 von 2 Lenovo ThinkPad S431 Integrated Camera  Replacement, Integrated Camera: Schritt 5, Bild 2 von 2
    • Unplug the connector. It is located on the top of the screen attached to the camera assembly.
  6. Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 6, Bild 1 von 3 Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 6, Bild 2 von 3 Lenovo ThinkPad S431 Integrated Camera  Replacement: Schritt 6, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 2,233
