Einleitung
This guide will show you the steps to safely remove the damaged integrated camera from your laptop. The integrated camera is located above the screen of your laptop, which is usually used to take pictures, create videos, and chat with others.
Was du brauchst
Unplug the connector. It is located on the top of the screen attached to the camera assembly.
In diesem Schritt verwendetes Werkzeug:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Use the 3.0 flathead to lift up the silver camera strip.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
