Einleitung
This guide will show you how to prepare the computer for the removal of the panel underneath the keyboard.
Was du brauchst
Identify the lock mechanisms holding the battery in place.
Slide each button outward with your fingers to disengage the battery.
Pull the battery off with your hand to separate it from the laptop.
Locate the thirteen 10 mm Phillips #1 screws securing the bottom panel of the laptop.
Remove the thirteen indicated screws with a Phillips #1 screwdriver.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
