Zum Hauptinhalt wechseln
Nextplay NP109CR Speakers Replacement
Was du brauchst
  1. Nextplay NP109CR Speakers Replacement, Speakers: Schritt 1, Bild 1 von 1
    • Turn the device over so it is upside-down.
  2. Nextplay NP109CR Speakers Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the 4 screws closest to the screen.
  3. Nextplay NP109CR Speakers Replacement: Schritt 3, Bild 1 von 1
    • Flip over the device so it is right side up.
  4. Nextplay NP109CR Speakers Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the 2 screws on the top of the device, next to the docking plug.
  5. Nextplay NP109CR Speakers Replacement: Schritt 5, Bild 1 von 1
    • Take off top piece by using slight force and pulling off.
  6. Nextplay NP109CR Speakers Replacement: Schritt 6, Bild 1 von 1
    • Unscrew the button board with smaller screwdriver.
  7. Nextplay NP109CR Speakers Replacement: Schritt 7, Bild 1 von 1
    • Lift off the button board.
  8. Nextplay NP109CR Speakers Replacement: Schritt 8, Bild 1 von 1
    • Unscrew all visible of the screws on the black logic board cover with the larger screwdriver.
  9. Nextplay NP109CR Speakers Replacement: Schritt 9, Bild 1 von 1
    • Lift the screen vertically straight up.
    • As you do this the logic board should move off with it.
  10. Nextplay NP109CR Speakers Replacement: Schritt 10, Bild 1 von 1
    • Flip the screen and the logic board over to the right side.
  11. Nextplay NP109CR Speakers Replacement: Schritt 11, Bild 1 von 1
    • Pull out the white plug that goes from the speakers to the logic board.
    • Then plug back in making sure it is completely connected.
Abschluss
Michelle Read
1 Reputation
1 Anleitung geschrieben
Cal Poly, Team 7-50, Forte Fall 2012 Mitglied von Cal Poly, Team 7-50, Forte Fall 2012
CPSU-FORTE-F12S7G50
5 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 401
