Zum Hauptinhalt wechseln
Dell Inspiron 14z-5423 Memory Modules Replacement
Was du brauchst
  1. Dell Inspiron 14z-5423 Memory Modules Replacement, Close the Display: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in "Before You Begin". After working inside your computer, follow the instructions in "After Working Inside Your Computer".
    • Close the display and turn the computer over.
  2. Dell Inspiron 14z-5423 Memory Modules Replacement, Loosen the Screw: Schritt 2, Bild 1 von 1
    • Loosen the captive screw that secures the memory-module cover to the computer base.
  3. Dell Inspiron 14z-5423 Memory Modules Replacement, Lifting the Cover: Schritt 3, Bild 1 von 1
    • Using your fingertips, lift and slide the memory-module cover out of the slots on the computer base.
  4. Dell Inspiron 14z-5423 Memory Modules Replacement, Remove the Memory Module: Schritt 4, Bild 1 von 1
    • Remove the memory module from the memory-module connector.
  5. Dell Inspiron 14z-5423 Memory Modules Replacement, Align the Notch: Schritt 5, Bild 1 von 1
    • Align the notch on the NEW memory module with the tab on the memory-module connector.
  6. Dell Inspiron 14z-5423 Memory Modules Replacement, Sliding the Memory Module: Schritt 6, Bild 1 von 1
    • Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.If you do not hear the click, remove the memory module and reinstall it.
  7. Dell Inspiron 14z-5423 Memory Modules Replacement, Slide the Tabs: Schritt 7, Bild 1 von 1
    • Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
  8. Dell Inspiron 14z-5423 Memory Modules Replacement, Tighten the Screw: Schritt 8, Bild 1 von 1
    • Tighten the captive screw that secures the memory-module cover to the computer base.
Ziellinie
Terrence15
79.121 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.985 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 200
