Einleitung
In this guide, we will be showing you how to remove and replace the Memory Modules.
Was du brauchst
Loosen the captive screw that secures the memory-module cover to the computer base.
Using your fingertips, lift and slide the memory-module cover out of the slots on the computer base.
Remove the memory module from the memory-module connector.
Align the notch on the NEW memory module with the tab on the memory-module connector.
Slide the memory module firmly into the connector at a 45-degree angle and press the memory module down until it clicks into place.If you do not hear the click, remove the memory module and reinstall it.
Slide the tabs on the memory-module cover into the slots on the computer base and snap the memory-module cover into place.
Tighten the captive screw that secures the memory-module cover to the computer base.
