Zum Hauptinhalt wechseln
Dell Inspiron 14z N114z Display Assembly Replacement
Was du brauchst
  1. Dell Inspiron 14z N114z Display Assembly Replacement, Remove the Screws: Schritt 1, Bild 1 von 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer. Follow the instructions in "Before You Begin".
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Remove the two screws that secure the display assembly to the computer base.
  2. Dell Inspiron 14z N114z Display Assembly Replacement, Turn over the Computer: Schritt 2, Bild 1 von 1
    • Turn the computer over and open the display as far as possible.
  3. Dell Inspiron 14z N114z Display Assembly Replacement, Lifting the Connector Latch: Schritt 3, Bild 1 von 1
    • Lift the connector latch and disconnect the display cable from the connector on the system board.
  4. Dell Inspiron 14z N114z Display Assembly Replacement, Note the Routing: Schritt 4, Bild 1 von 1
    • Note the routing of the display, camera, and mini-card antenna cables, and remove the cables from their routing guides.
  5. Dell Inspiron 14z N114z Display Assembly Replacement, Remove the Screws: Schritt 5, Bild 1 von 1
  6. Dell Inspiron 14z N114z Display Assembly Replacement, Lifting the Display Assembly: Schritt 6, Bild 1 von 1
    • Lift the display assembly off the computer base.
  7. Dell Inspiron 14z N114z Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 1 von 2 Dell Inspiron 14z N114z Display Assembly Replacement, Placing the Display Assembly: Schritt 7, Bild 2 von 2
    • Place the NEW display assembly in position and replace the two screws that secure the display assembly to the computer base.
    • NOTE: Ensure that no cables are caught between the display assembly and the computer base.
  8. Dell Inspiron 14z N114z Display Assembly Replacement, Route the Cables: Schritt 8, Bild 1 von 1
    • Route the display, camera, and mini-card antenna cables through their routing guides.
  9. Dell Inspiron 14z N114z Display Assembly Replacement, Sliding the Display Cable: Schritt 9, Bild 1 von 1
    • Slide the display cable in the connector on the system board and press down the latch to secure the cable.
  10. Dell Inspiron 14z N114z Display Assembly Replacement, Replace the Screws: Schritt 10, Bild 1 von 1
    • Turn the computer over.
    • Replace the two screws that secure the display assembly to the computer base.
Ziellinie
Terrence15
79.161 Reputation
441 Anleitungen geschrieben
RampUP America, Inc. Mitglied von RampUP America, Inc.
Community
42 Mitglieder
1.986 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 7
Insgesamt: 178
